disscus O_o 700hp electric car
Will Lightning Strike in the UK? - MSN Autos discuss i personally dont belive its possible to many computers =to much that can go wrong if just one of them is out of sync plus the company says it still requires additonal funding still a bold idea i think
Looks pretty good, I find it odd that the company kept it quiet for so long. The "sound module" seems like a moronic idea in my book.
"Throttle till you see light, then brake like HELL!!"
My Last.fm Top 20:
My Last.fm Top 20:
I doubt it lives up to its name, but hey, If it does I'd rock it.
448WHP/420WTQ
Full bolt-ons+H/C
Car Sound Clip & More(W/ Mekanic)
Tuned by Precision Motorsports
448WHP/420WTQ
Full bolt-ons+H/C
Not going to happen. A 700hp electric motor is going to make several thousand ft-lbs of torque down low. 700hp is over 500,000W of power. That's a lot to draw, and will require lots of storage. That's also a lot of heat to cool down even at 90% efficiency.
Here are a few Prius electric motor specs (hey, it's on it's 3rd version):
HP = 67
TQ = 295
Battery weight = 100 lbs
Battery capacity = 1300 W/Hrs
Scale that up to 700hp and that's 3000ft-lbs of torque. Hook that up to a Prius battery and go full blast and it'll last a little over 9 seconds. Want to go longer, start adding up the 100 lb batteries. If they're using Lithium, improve your numbers by about 20-30%.
HP = 67
TQ = 295
id drive it power is power ! not to change the topic but did you here that f1 is going hybride !!!!???? wtf there givin the opion to run a knetic capture system that will take some to power from drakeing store it and then use it in the power of the car. ?
one bad brotha!
one bad brotha!
