swap question
Old Jul 9, 2008 | 11:34 AM
slickrickwest's Avatar
Default swap question
ive got an obd0 integra and instaled an obd1 eng and ecu will an obd0 distributor work with the obd1 ecu ive pulled up wiring diagrams and all the outputs seem the same im just not sure if its the ecu i got or if i really need the obd1 distributor if anyone has any info please let me know
Old Jul 9, 2008 | 11:38 AM
Garrett's Avatar
pfft.....
you may be better off in the honda tech forum....
Old Jul 9, 2008 | 12:15 PM
GSRedd's Avatar
The Peoples Champ
ecu and the dizzy need to be the same both obd1 or obd0 no mix match
Old Jul 9, 2008 | 12:54 PM
John's Avatar
lol @ tampa
correct. If you were already obd1 then you could use a obd2 dizzy (rewired) but thats the only case where you can use a diff ecu and dizzy
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
