subaru svx ......?
Old Feb 2, 2008 | 11:35 PM
slizzle's Avatar
has a new plan in action
Default subaru svx ......?
i never heard of one and yesterday i seen 2 of them ive never seen this car before in my life wtf is it tell me more about this car
you gotta get it from the muscle cuz dont nobody owe you nothin
Old Feb 3, 2008 | 01:20 AM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
its a 6 cylinder boxer subaru coupe. pos really.
Old Feb 3, 2008 | 04:13 AM
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
They're ugly as fuck.
That is all.
-Winston Churchill
Old Feb 3, 2008 | 04:35 AM
cosworth34677's Avatar
there not the greats looking cars that a fact but a peice of crap far from it!!
back it the day these were as fast and the 300 gt's and mustangs and not supras but they were it that class . there were awd boxer 6 some came turbo not many though the car mags love the way the cars handled and the way the cars drove car and driver call it the poor mans porshe (<-- spelled wrong) . i'll find some specs for you
Subaru SVX, Subaru, SVX, Pictures, FAQ, transmission, wheel bearings, Alcyone, Alcyone
Subaru SVX Specs Overview
Engine: 3.3-liter 24-valve 6-cylinder horizontally opposed
Horsepower: 230 bhp
0-60 MPH: 7.3 seconds
1/4 Mile: 15.4 seconds @ 92.5 mph
Skidpad: 0.85 g
Top Speed: 143 mph
Mileage: 17 / 25 mpg
Weight:
3,580 pounds
Detailed Subaru SVX Specs
Engine
Type: 6-cylinder horizontally-opposed (boxer) for low center of gravity and reduced vibration
Construction: Die-cast aluminum ally block, cast aluminum alloy heads with 4 valves per cylinder and centrally located spark plugs
Valve Train: 24-valve, with dual overhead camshafts (DOHC) and hydraulic valve lash adjusters
Displacement: 3.3 liter / 3318 cc / 202.5 cubic inches
Bore and Stroke: 96.9 mm x 75 mm / 3.815 inches x 2.95 inches
Compression Ratio: 10.0:1
Horsepower: 230 @ 5,400 rpm
Torque: 228 @ 4,400 rpm
Maximum Engine Speed: 7,000 rpm
Engine Management: Integrated fuel and ignition systems. Engine Control Unit (ECU) computer with learning and aging controls, self-diagnosis and limp-home features. Twin knock sensors and oxygen sensors provide separate control of each cylinder bank.
Fuel System: Multi-port electronic fuel injection with dual-spray fuel injectors
Fuel Required: Unleaded 91 octane
Ignition System: Distributorless electronic crank-angle-dependent direct-fire ignition with individual spark/coil units at each platinum-tipped spark plug
Exhaust System: Twin downtube headers and dual catalytic converters for reduced back pressure
Transmission
Type: Fully automatic 4-speed (4EAT) with electronic shift control, automatically-engaging overdrive and lockup torque converter
Transmission Management: Transmission Control Unit (TCU) computer monitors engine speed, vehicle speed, brake system engagement and ABS engagement and communicates with engine management computer.
Automatically selects between Power and Economy modes based on throttle input. Power mode upshifts at higher engine speeds for increased acceleration.
Manual mode allows driver to reduce wheel spin on difficult surfaces by starting in second gear
Gear Ratio: Gear Ratio Overall Ratio (rpm) mph
1st 2.79:1 9.90:1 (6400) 43
2nd 1.55:1 5.50:1 (6200) 76
3rd 1.00:1 3.55:1 (6200) 118
4th 0.64:1 2.27:1 (4890) 143
Final Drive Ratio: 3.55:1
Rpm @ 60 mph in 4th: 2050
Chassis
Body Construction: Unit body type, with front and rear energy-absorbing impact-crumple zones
Front Suspension: Independent, with long-travel, low-friction, variable-damping gas-pressurized struts; coil springs; lower L-arms with liquid-filled bushings and stabilizer bar. Subframe supports L-arms for high lateral rigidity
Rear Suspension: Independent, with long-travel, low-friction, variable-damping gas-pressurized struts; coil springs; Dual Parallel Links for passive 4-wheel steering; trailing links; stabilizer bar and anti-dive/anti-squat geometry
Acceleration
0-30 mph: 2.8 seconds
0-40 mph: 4.0 seconds
0-50 mph: 5.3 seconds
0-60 mph: 7.3 seconds
0-70 mph: 9.4 seconds
0-80 mph: 11.6 seconds
0-90 mph: 14.2 seconds
0-100 mph: 18.2 seconds
1/4 mile: 15.4 seconds @ 92.5 mph
Handling
Lateral Acceleration: 0.85g
Balance: Moderate understeer
Speed through 700-foot Slalom: 60.2 mph
Braking
Brakes: Power-assisted, with dual diagonal hydraulic circuits. 11.89-inch ventilated front discs with twin-piston sliding calipers. 11.42-inch solid rear discs. Drum in rear disc-type parking brake
Anti-lock Braking System (ABS): 4-channel, with one hydraulic ABS circuit per wheel
Minimum Stopping Distance: From 60 mph: 134 feet
From 80 mph: 229 feet
Control: Excellent
Pedal Effort for 0.5g Stop: 15 pounds
Fade, Effort After Six Stops from 60 mph: 22 pounds
Brake Feel: Very good
Overall Brake Rating: Excellent
Dimensions/Weight
Wheelbase: 102.8 inches
Length: 182.1 inches
Width: 69.7 inches
Height: 51.2 inches
Track, Front/Rear: 59.1 inches / 58.3 inches
Interior Volume: 84.9 cubic feet
Trunk Volume: 8.2 cubic feet
Road Clearance: 5.3 inches
Curb Weight: 3,580 pounds
Weight Distribution: 59/41
Wheels: 16 inch x 7.5JJ unidirectional aluminum alloy
Tires: Bridgestone Potenza all-season steel-belted radial 225/50VR16
Steering
Type: Rack-and-pinion with engine-rpm sensing variable power assist. Impact-collapsible steering column
Turning Circle: 35.4 feet
Turns, Lock to Lock: 3.1
Accommodations
Seating Capacity: 4
Front Seat Travel: 9 inches
Front Seat Back Adjustment: 80 degrees
Lateral Seat Support: Very good
Seat Width, Front/Rear: 20.5 inches / 22.0 inches
Headroom, Front/Rear: 37.5 inches / 35.0 inches
Legroom, Front/Rear: 43.5 inches / 28.5 inches
Shoulder Room, Front/Rear: 56.1 inches / 54.5 inches
Instrumentation: 160 mph speedometer, 9,000 rpm tachometer, coolant temp, fuel level
Interior Noise
Maximum in 1st Gear: 70 dBA
Constant 50 mph: 63 dBA
70 mph: 67 dBA
EPA Mileage Estimates
City: 17 mpg
Highway: 25 mpg
Capacities
Fuel Capacity: 18.5 gallons of premium unleaded
Engine Oil Capacity: 6.3 quarts
Coolant Capacity: 7.4 quarts
Towing Capacity: Maximum total trailer weight: 2000 pounds; Maximum trailer tongue weight: 200 pounds
Recommended Maintenance
Oil Change: 7,500 miles
Oil Filter Change: 15,000 miles
Tuneup: 15,000 miles
one bad brotha!
Old Feb 3, 2008 | 05:04 AM
friend088's Avatar
I definitely remember this car when I was younger. Had somewhat of a futuristic look to it because of the weird windows, but yes, somewhat ugly and did NOT sell well.
Old Feb 3, 2008 | 07:54 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
You people are weird, that car looks HOT. I love seeing them randomly around my hometown
ASE: Brakes
Old Feb 3, 2008 | 08:21 AM
KrazyRider83's Avatar
Fawkin Skittles
not that they didn't sell..I think somewhere around 14k made it to the states (i'll get more info). Car was designed by subarua with motor & all, but had some input from mclaren. Window design was from mclaren, supposed to be beneficial to get minimal wind buffer & rain in when having the window down. My buddy had one, & it is very comfy, motor lacks the power, but pretty quick. You either love it or hate it, I personally liked the looks. All wheel drive was ok. Car does sit low, & back seats aren't so roomy. People have done a manual swap using the sti tranny. Kinda have to see the thing up in person, it's not that bad.
04 Neon SRT - (rebuild time)
03 B5.5 Passat Wagon 1.8T
Originally Posted by efficientkiller
none of this really matters at the end of the day...if you really want to know, the true answer is found in research, why post a ignorant thread & call it a debate? this is exactly why TR gets the critizism it does...
Old Feb 3, 2008 | 08:22 AM
K20A2's Avatar
I couldn't justify a 4.5k+ transmission swap on a car like that.
-Winston Churchill
Old Feb 3, 2008 | 08:26 AM
Fawkin Skittles
here some info..
Subaru SVX .com
Old Feb 3, 2008 | 09:06 AM
JP Money's Avatar
^is awesome personified
A guy at my work drives a black one with a black interior. I think he's the original owner too. Its definitely is different. Personally I think its ugly, but not Aztec ugly.
Originally Posted by Dwight
Reject a woman, and she will never let it go. One of the many defects of their kind. Also, weak arms.
