Things that are wrong with your car.....
why vivek hopes to see me get a newer car as my daily driver and why i can't wait to get my b20 in there:
stock replacement clutch
oxygen sensor which will hopefully end my code 43 fuel delivery system problem over 70mph fixed
small vaccum leak in brake booster...it was the Oxygen Sensor throwing the idle off
back brakes keep warping the drums need to change to organic or ceramic shoes
timing belt seal causes oil leakage
and since my car hates coolant who knows which hose i will replace next shouldn't have made this statement, the 3 week old hose had to be replaced again Friday night. I hate faulty hoses
but I can replace them faster and faster
rough idle (manual calls for new ecu trial)...fixed
this car is making me a shade tree mechanic
but I can replace them faster and fasterrough idle (manual calls for new ecu trial)...fixed
if you can only race me in a straight line then whats the point
...91 SMF SCCA
...91 SMF SCCAhttp://www.flickr.com/photos/8341770@N07/5601083432/http://www.flickr.com/photos/8341770@N07/5601083432/ by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Knock on wood , nothing.
I've never had a problem with my car, 76,000 miles.
Like I said, knock on wood.
www.locustom.com
www.locustom.com
hmmmm
-rear pass window tint is failing
-sunroof motor came off track (takes awhile to fix
-stereo wiring is functional but not pretty or done
-all calipers are faded
-all pads are done
-all rotors are done, one is cracked
-brake fluid needs flushing
-front grille needs replacing
-stupid egr vac line keeps popping off
-causing a check engine light and bad mileage
-paint is showing signs of fading on mirrors and clear coat again on the wing
- cams + 02 outlet needs to go on then tuned
-but i need to do timing belt, balance belt, and water pump all together with the cams
-might as well do cam gears too
I got a lot of work to do!
-all pads are done
Paint, fuel pump, driver door ( don't ask, but involved a friend that can't drive a stick and my truck), and tires..... well we know why it needs tires
Mikey's toys:
1984 Fila Thunderbird
302 4 barrel, Mac equal length headers, MSD 6AL, Holley 4160, Lokar cables, Mini starter, 84 Stang' GT Valve covers, 3G alt, Cougar E fans, Summit H pipe, Summit race mufflers with turndowns, 7.5" 3.08 TL, Lots more little stuff
1 day till bootcamp!!!!
Mikey's toys:
