Things that are wrong with your car.....
Old Oct 31, 2007 | 09:23 PM
Puto's Avatar
El Puto ©
Originally Posted by Mars_302
it needs to have the headliner redone
cage welded in
engine repainted
engine re-gasketed
engine dropped in
transmssion bolted up
new flywheel and clutch setup
new exhaust setup
the correct v8 shocks and struts
the v8 fuel lines attached
wiring ran
new carpet installed
new weather strip installed
interior put back together
car painted
You win!
Old Oct 31, 2007 | 09:30 PM
Tengo's Avatar
mazda protege5
rear quarter panel damage
front bumper damage
transmission speed sensor dead
Old Oct 31, 2007 | 09:46 PM
Vash350Z's Avatar
Looks Fast
Needs:
JWT Clutch + Flywheel
Vortech 2.87 pulley
Central 20 3.9FD
C-west side and rear skirts
2007 VW Rabbit 2-Door
2004 Nissan 350Z Track
1980 Toyota Corolla 2-Door Sedan
1979 Chevrolet Corvette L82
Old Nov 1, 2007 | 03:53 AM
tobibeck80's Avatar
Nordschleife addict
need new window lifter for the driver side, power lifters for my trunk, they are too weak.
And my seat is creaking......all those defects above are BMW E36 compact weaknesses.
My exhaust rattles a little bit, don't care because there will be a new one.
Car needs to be painted.
except for that it's in great shape.
Old Nov 1, 2007 | 04:07 AM
P057's Avatar
isuck
Need to wash.
5k service coming up late this month or early next month.
........ that's it.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
TEGGYGIRL's Avatar
i need a door handle thanks to my friend pulling it off
and a drivers seat -has a rip
will need a cv axle soon
Old Nov 1, 2007 | 04:09 AM
  #17 (permalink)
3drwhore's Avatar
Pending....
I dont need anything. my car is running good.
**EDIT**
I need gas.
Old Nov 1, 2007 | 04:12 AM
  #18 (permalink)
Suicidal Racing's Avatar
Has V.I.P in HELL!
hmm
it sucks building cars from the ground up
needs
4 banger pulled
trans pulled
7.5 rear pulled
all the suspension and k-member pulled
8.8 rear end built and put in
trans and stall built
engine for the car needs to be torn apart
arp rod bolts and bolts have to be installed
put fresh rings and bearings in the engine
heads needs to be ported
heads need to be built
intake needs to be ported
fogger system needs to be installed and flowed
install the cam and put the top end on.
carb put on the engine
install engine
install trans and converter
make engine plate
fab up headers and exh
have a drive shaft built
wire the car
design and install fuel system
install new brake system
install interior
install cage
install seats
install gauges
install new suspension and k-member
fit the fiber glass hood
fix some lights
paint the car
Old Nov 1, 2007 | 04:28 AM
  #19 (permalink)
cha0tic's Avatar
damn i need a alot of shit for both of my vehicles. i'm moving next weekend so ive been saving up.
integra:
all new motor mounts, body work, exhuast leak, exhuast hangers, new distributor, tuneup and a bunch of other small things.
ranger:
new ecu, new rear drums, hubs tightened, tuneup
Old Nov 1, 2007 | 05:50 AM
  #20 (permalink)
flobeck263's Avatar
I need:
-New sway bars, the stock ones are to weak, i´ll putting in some of the Z3 M-Roadster
-New Paintjob, color is great but scratches everywhere
-new passenger door panel
-new water pump, thermostat and v-belts before they are braking down (BMW sickness)
-new door handles, paint is wearing off
-short shifter, also from the Z3 M-Roadster
-drive train flexible disc
-some H7 headlights, the original HB3/HB4 are like candles
www.BMW-Syndikat.de
