Need Tool Help ASAP!
Old Oct 3, 2007 | 11:29 AM
Ahhhh Nick!'s Avatar
Out Of Towner
Exclamation Need Tool Help ASAP!
I rented a pulley puller kit from Discount Auto & I got one of the pushrod stuck inside the long screw that pushes against the crank. The rod isn't threaded or anything, I guess it's just stuck in there somehow. I have it in the oven and I'm hoping it'll loosen up the metal and I can pull them apart. Any other ideas?
Old Oct 3, 2007 | 11:47 AM
F*r*a*n*k*e*i's Avatar
You did what? Are you saying the center screw that you tighten on the pully kit went into the hole on the end of your crank?
Old Oct 3, 2007 | 11:55 AM
Out Of Towner
No, the long rod (top right of the picture). Is stuck inside the short threaded bolt (right below the long rod in picture).
Old Oct 3, 2007 | 02:27 PM
Out Of Towner
I got it out. Vise & bigass hammer always does the trick!
