Bov Help Plz!!!!!!
ok i just recently got an '05 srt-4 and i am looking to put a new bov on it b/c it only has the mopar right now!!im either going to put the hks ssqv or greddy type s!!the only problem is i dont know what all do i need to have it installed on my car??like i know i need the bov with the flange to be welded on but i dont know if i need like special piping or whatever to have it welded onto??the piping on the car is stock so plz help me out and lemme know if i need more parts to make this happen!!THNX
i believe the srt4's have plastic piping, if thats true youd need aluminum piping to have the new bov welded onto it
formally known as d33flat
1991 nissan 300zx - Sold
1989 240sx sil80. not stock anymore yay!(dead in the driveway)
2005 Dodge SRT4 (new DD!)
Everyone knows those mopar bov's are defective past 7 psi. Its a good thing you chose to replace it, a bov is the most important part in a car. I just had to replace my grandmother's stock bov in her van with a turbo xs RFL bov, I highly reccommend it! Maximum SWOOSH and full on Pee-SHOOOOOO. It would be great for someone like you!
7! pints of ale out the window sill
when I get my fill I'm chilly chill
Makes perfect sense.
Putting on a bov gives you no power increase,and it can actually make your car run worse.
If you knew anything about cars you would know this.
Go with a bpv(ByPassValve).It redirects the air that is in the piping when you let off the throttle back into the intake instead of to the atmosphere.
-Winston Churchill
-Winston Churchill
Go to AgpTurbo.com,order the hard pipes,bov,and block off plate...A BOV on a Srt-4 does not hurt your performance,like Subarus.
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
i own a srt4 u will need to buy custom hardpipes..
look on srtforums.com there is alota used ones i would reccmonnd buying also... u will have to redue ur vaccum setup.. take out alota ur stock vaccum lines cuz ur not using ur surge vavle or mopar bov anymore.. soo its hard to explain but msg me and ill give u sum help
60 - T R I M
2005 SRT-4 w/ No Grip
and a power increase on SRT4 u will gain a lil power increase more hold on boost.. and better WOT instead of plastic tubing can open up clamps and release air cuasing boost leak.. so i reccmoond buy hardpipes.. u will see lil gains.. in boost holding and a sexi sound
i have a 50 trim srt4 i use a hks w/ ed hardpipes.. exhaust depot pipes
60 - T R I M
