tire vibration problem??
Old Aug 26, 2007 | 03:01 AM
ottoman#1's Avatar
Default tire vibration problem??
For some reason i keep getting this vibration when i turn left, now keep in mind i just pute new tires and rims on that were the same size as stock, i had a alignment done and rebalanced, cv axles and bearings been replaced, what am i missing,,,, could it be the treads on the Hancook tiers are to aggressive and dig in to much when i turn? -- what do you think , otto
Old Aug 26, 2007 | 04:54 AM
redcoats1976's Avatar
i take it this is something that started after doing all these things,not something it was already doing? try putting the front wheels and tires on the rear and see if it still vibrates,at least that way you rule out defective wheel/tire combo(out of round or balance)
Old Aug 26, 2007 | 05:34 AM
Chuck 98 RT/10's Avatar
Sexist
If is just vibrates when turning left, swap the tire left to right and see if the vibration swaps too. If so, you know it's the tire. If not, it's something else.
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
