Torque wrench (click type)
what brand of torque wrench are u using? (click type)
and how does it work? i am about to buy one
and wonder how does it work
there is a twist knob by the end of the handle and also some scales on the
body of the wrench.
adjust it to the number i want and thats it ?
body of the wrench.
Once you hear the click stop applying force. when your done don't leave it loaded take the setting back to zero, it will last you longer and maintain its accuracy.
Originally Posted by George Orwell 1984
Its presupposed that somewhere or other, outside oneself, there was a "real" world where "real" things happened. But how could there be such a world? What knowledge have we of anything, save through our own mind? All happenings are in the mind. What ever happens in all minds, truly happens.
Originally Posted by Funk
Your mind contains the whole universe, the key is being able to see past yourself, this world, and thought itself.
i have a craftsman. i suggest getting a craftsman or husky, or another that has a lifetime warranty on it, they do eventually need to be recalibrated, i like the ease of taking it back and getting a brand new one. and like kapone said, always put the adjuster back down to its lowest setting.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
I've got a Husky. Well put together, good locking, easy to use, and you get a carry-case. I recommend it.
But at the lower torque settings, the clicks are very quiet.
you also have to assess how much you'll use it and what you're doing
if you're just TQing chassis stuff every once in a while, then its really not necessary to spend the extra money for a higher end one IMO
i have a $20 pep boys that gets me by for the small amount i use it, i'll eventually upgrade, but like i said, for now its an extra $80 or whatever better spent elsewhere
Craftsman click type
As mentioned earlier, gradually apply the torque until it clicks.
Yes
And always set back to zero.
Now that I'm getting old I wish I had one with a great big easy to read dial instead of those tiny little numbers on the handle.
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Chuck
