what else?
Is there anyway to visually look at a relay to see if it is good or bad. I lost my ohm meter
Interested in investing? Let me know and I will help you get started.
http://friends.zecco.com/r/55c661e4107a102cae57
this one has to be bad correct?
The best way to check it is plug it back in then turn the key on. You should hear the relay clicking if it is working. I've heard that if you use an ohm meter wrong on a 4 prong relay, you can damage it.
[img]webkit-fake-url://59a75c29-2baa-4768-85b0-a8297a03874c/imagejpeg[/img]Fuck senior honda/Bob
the relay looks like it heated up and the glue in it was melted.. I hope this is what happened..
take it apart
An alternative check of the contacts side, is to put a bulb wired to a ground on one of the contacts, and a wire to the battery on the other contact.-Bob
I went ahead and bought a new relay.. I still can't figure out the problem.. None of my guages or anything light up or neither does my radio turn on like it used to.. I still can't get this thing started...
What else should I check if my car won't start and I checked the battery. I checked the relays (the only ones I could find under the dash)..
The vehicle won't start.
I am thinking about push starting the car..
is it doing anything or completely dead, no power what so ever?
TR "Old Skool EF" Member #012
91 Honda Crx Si & 03 Lightning clone
~*~Ellie~*~
RIP Cisco Ramos, RIP Brian Nichols
~*~Ellie~*~
