Question about where cat converter and exhaust header meets
Old May 4, 2007 | 05:08 AM
MAYMAY's Avatar
Thumbs up Question about where cat converter and exhaust header meets
Question about where cat converter and the end of exhaust header meets
there are two long bolts with springs insert and two nuts to secure them
are i suppose to tighten them all the way until i cant turn the wrench any more or ??
i only tighten them up to 90%
Old May 4, 2007 | 05:12 AM
Ro.'s Avatar
Ro.
wouldn't you want to tighten it all the way?
Old May 4, 2007 | 05:21 AM
aaron1017's Avatar
is not Rotarded anymore!
On my Acura 2.2CL I could always tighten mine all the way until the nuts bottomed out. *shruggs*
LS1/T56 Heads Cam 1994 FD
Old May 4, 2007 | 10:58 AM
fourbanger's Avatar
White and Literate.
start it up and see if the flange gasket has set in properly(lil lead o-ring thingy)
Old May 4, 2007 | 11:52 AM
MAYMAY's Avatar
sure.i will check them.thanks guys..
the o metal ring does set properly...and securely too
Old May 4, 2007 | 12:14 PM
20+'s Avatar
20+
There should only be about 1/2" of thread and then it's smooth shank, so tighten until you reach the smooth part but make sure it's not bottoming out the spring
Old May 10, 2007 | 08:23 AM
By not bottoming out the spring, you allow some flex. That will reduce stress, and reduce future cracks/leaks.-Bob
Old May 10, 2007 | 08:26 AM
Mars_302's Avatar
Race Photographer
that spring is there to keep tension really so they dont back out on their own. Usually those bolts have a lip towards the thread and bottom out againist the lip.
Old May 10, 2007 | 08:45 AM
Ahhhh Nick!'s Avatar
Out Of Towner
Man, just be like every Honda owner out there and ditch the exhaust pipe. HEADER OUT BABY!!! hahaha
Old May 10, 2007 | 02:41 PM
Gooser's Avatar
has his own parking spot
Whats a Cat?!?!
