cnc flanges?
i need a set of head flanges for a 2007 g35. i havn't gotten the gasket yet, but i probably will tomarrow. i can put them in cad (dwg file) and then i'll need them cut. not sure if the ports are different from earlyer 350z or g35.
anybody know where i can get a set cut for under $150 in less then a week?
i usually deal with bmc, however i can't wait a month to get them.
any help would be great.
im guessing flanges for headers
why dont you laser cut or waterjet them? i can tell you the place i use if you want
Rapid Metal Products
4243 Holden Road
Lakeland, Florida 33811
Phone:863.701.0058
Fax: 863.648.5027
4243 Holden Road
Phone:863.701.0058
Fax: 863.648.5027
i'll give them a call today. thanks
1/2" steel? for a header flange?! talk about overkill.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
yeah, seems like a lot to me also. i know using the thicker stuff will help keep the whole thing from warping from the heat, but all i do is run tacks all around, kinda like tightening a tire down. then add more till i know that bitch wont flex, then burn her in. but im not trying to tell you how to do anything at all, ive seen your work and its great man, you are doing a good job.
but i know for a fact ive seen it with my own eyes, 3/4" steel with their water jet and only a fraction of a degree of taper, it was incredible. i could barely register anything on my caliper
but with 1/2", you will def have to have them waterjetted. i think they only go up to 1/4" with the laser.
they do top notch work. i had them cut a shit ton of stuff for our formula and baja this year. everything from tabs, brake rotors, ARB mounts, steering rack mounts, swing arm etc
no offense guys, but i've been making turbo manifolds for about 5 years now.
1/2 mild steel is the way to go.
bmc had one set, so i had them shipped today.
i'll post up some pictures of them when i get them. you'll get an idea of what i'm talking about.
i'll try your guy in the future though. definatly nice to have people.
sorry to dig up an old thread, but any other laser cutting or waterjet cutting places that are closer to tampa that do good work? i need something cut in 3/8ths steel plate, and drivin to lakeland wouldnt be possible during normal buisness hours for me. the part will be about 20in in diameter. its a transmission adaptor i am drawing up in solidworks. thanks.
http://www.cardomain.com/ride/2042690/1 black 84 supra, 7mgte, truetrac, bbk, etc.. more in the works
http://www.cardomain.com/ride/2117186/1 blue 85 supra, beater
http://www.cardomain.com/ride/2965297/1black 86. saved from the crusher! wicked setup on the way.
http://www.cardomain.com/ride/2235741/1 64 chevy c10, finally getting a new body. woot!
we are using them this year, but don't know if they do stuff for outsiders
i have a special situation with them
give them a shout
