car batterys
Old Feb 4, 2007 | 12:49 PM
Whaazup17's Avatar
Default car batterys
are car batteriess what are they 12 volts and 60 amps?
Whaazup17's Avatar
or is it 6 volts? I think a car battery is 6 volts..
Old Feb 4, 2007 | 12:55 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Car battery today is 12.6v...2.1v per cell, 6 cells.
Amps...well that depends on the battery. The average sedan should have 640 cold cranking amps.
ASE: Brakes
Old Feb 4, 2007 | 12:57 PM
Whaazup17's Avatar
ohh.. my charger doesn't go up that high.. I have 12 volts and then another setting for amps.. 60 amps in the max..
Old Feb 4, 2007 | 01:44 PM
Whaazup17's Avatar
When it says charging at 2 amp / 20 amp/ 60 amps
is that 2 amps/ hour
20 amps/hour
60 amps/hour
and a fully charged battery is what like 600 amps?
Old Feb 4, 2007 | 02:11 PM
Thats the rating of how fast it will charge I think...your charger should work fine
ASE: Brakes
Old Feb 8, 2007 | 09:45 PM
Most chargers will charge any battery. Slow charging with low amps is probably better. Some people use the higher amps only when they are in a hurry, and with some chargers, in an EMERGENCY, some people use the higher amp setting as a short-term jump starter.
Car batterys are 12 volts, unless you want something special. -Bob
Old Feb 8, 2007 | 10:59 PM
BLUE2KSS's Avatar
Mechanical Engineer
a trickle charge is best for your battery, to recharge it anyway
but like it was said before, you can use that battery charger as a jump starter or a quick fix to get your ass to work and home at most with a really fast charge
but your battery charger will work just fine
