soft brakes help
ok i just put some powerslot front rotors on my car and new pads all around after fighting with the rear calipers and bleeding my brakes my brake stop fine but are realy soft feeling i think the stoping power im getting is just because of the less fade you get from slotted rotors and not the brake pressuer im putting on them..
any ideas way they feel so soft ?
one bad brotha!
one bad brotha!
In what order did you bleed the brakes?
Try again.
I'm about to get caught up again by Sunday afternoon,
if you need some help. -Bob
Try again.
Did you bed your brakes yet?
If not this is a serious problem.
New rotors+new pads = brakes feel like crap until they are bedded properly.
Also you should not be getting any sort of fade on the street unless you are hammering on your brakes REALLY hard.
well the brake on the car stock were good but i put the rotors on a week ago before the pad .. because i got the run around from the part store abou thte pads. but just on the old pads the freakin car stop so myckh better withe the new rotors .. but know when i put the new pad on the think is all mushy like it like a mini van. so i think that it may not bedded like he said but i'll try bleed the brakes agin to it couldn't hurt !
one bad brotha!
one bad brotha!
