Is it possiable
Is it possiable
For a AWD car to launch and pull its front wheels off the ground?
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
i would def. think it would matter on the bias, maybe not totally but it would most certainly come into play
yeah, it would make it easier, but then why not put 100% on the rear
it doesn't matter, but yes it would make it easier
EDIT: that says you don't kill the drivetrain on a launch that hard
so you're saying a car with a 90% front bias and a car with a 90% rear bias have the same chance of pulling the front wheels off the ground?
i don't even know where to start...
first you say it would make it easier (which means it would matter), then you say it doesn't matter, and then you say it would make it easier (which means it would matter). which is it?
so with enough power it is possiable even with a 50/50 system?
no, i said it would make it easier with a higher rear bias, but even if its got 90% front, if you have like....5K HP thats 500HP out back, and that'll lift it
i said it would be easier with higher rear bias, but wouldn't matter, as in its possible with a different bias, why are we having a symantec argument?
