Dynamic Compression Ratio
Definition: The Compression Ratio (CR) of an engine is the ratio of the cylinder volume compared to the combustion chamber volume. A cylinder with 10 units of volume (called the sweep volume) and a chamber with a volume of 1 has a 10:1 compression ratio. Static Compression Ratio (SCR) is the ratio most commonly referred to. It is derived from the sweep volume of the cylinder using the full crank stroke (BDC to TDC). Dynamic Compression Ratio, on the other hand, uses the position of the piston at intake valve closing rather than BDC of the crank stroke to determine the sweep volume of the cylinder.
The difference between the two can be substantial. For example, with a cam that closes the intake valve at 70º ABDC, the piston has risen 0.9053" from BDC in a stock rod 350 at the intake closing point. This decreases the sweep volume of the cylinder considerably, reducing the stroke length by almost an inch. Thereby reducing the compression ratio. This is the only difference between calculating the SCR and the DCR. All other values used in calculating the CR are the same. Note that the DCR is always lower than the SCR.
Dynamic compression ratio should not to be confused with cylinder pressure. Cylinder pressures change almost continuously due to many factors including RPM, intake manifold design, head port volume and efficiency, overlap, exhaust design, valve timing, throttle position, and a number of other factors. DCR is derived from measured or calculated values that are the actual dimensions of the engine. Therefore, unless variable cam timing is used, just like the static compression ratio, the Dynamic Compression Ratio, is fixed when the engine is built and never changes during the operation of the engine.
Kennedys DynoTune- Dynamic Compression Ratio Explained
Just something interesting I took time to read about today. I'd seen the term used on LS1Tech but never on any of the import boards I'm on- domestic guys seem to know a hell of a lot more about this kind of thing. Import guys will say "I'm getting the Stage 3 cams!!1"; domestic guys will say "I'm getting a custom cam from Comp Cams, a 236/230 114 LSA .601/.580 lift with this and such ICL to match my stock SCR of 10.8:1 which should yield a DCR of 8.32:1 and yadda yadda..."
Unfortunately it all seems to be focused on naturally aspirated V8 stuff. If anybody knows what numbers apply to a boosted engine feel free to let me know. I'll be trying in vain to find details about the aftermarket cams available for my engine other than "Gives +40 hp!!!1" and fake duration numbers.
Yes, several of them do, and going by the definition given on the sites above, they shouldn't. From what I'm lead to believe Dynamic Compression is just like Static Compression- swept volume over combustion chamber volume. The volume of the cylinder at BDC over the volume at TDC, or in the case of Dynamic Compression, the volume of the cylinder at IVC over the volume of the cylinder at TDC. Density of the intake charge has no effect on these values.
I'm mostly interested in knowing what kind of dynamic compression ratios people have luck with on boosted cars so I can try to piece together camshaft data to figure out good combinations of cams and static compression ratios.
