2000 celica gts launch prob
Old Nov 19, 2006 | 07:08 PM
Notladstyle's Avatar
King of Ricers
Crimp and solder new ground wires from the chasis to the spark source. You need more juice than the plugs are getting so they cant fire as fast as they need to.
notladstyle.blogspot.com
Old Nov 19, 2006 | 11:13 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
Originally Posted by hyperforce3
i drive like a ricer and my car broke
jkjkjk!
Old Nov 20, 2006 | 04:04 AM
SkwervE's Avatar
realer than most
Old Nov 20, 2006 | 07:14 AM
GTman85's Avatar
KBizzzle
Originally Posted by Orion ZyGarian
No, the fact that its a slow sorry excuse for a Celica is the problem
Dickhead responses were not was he was looking for. why must everyone have a gay ass response to a simple question
^^Makes me warm and fuzzzzy
Old Nov 20, 2006 | 07:15 AM
F*r*a*n*k*e*i's Avatar
I think the problem is that it's front wheel drive.
Old Nov 20, 2006 | 07:54 AM
MtuRbo2's Avatar
sergee-hoe
Traction Control?
Old Nov 20, 2006 | 08:19 AM
  #17 (permalink)
2kSnakeater's Avatar
Pastafarian FOR LIFE!!!!!
fwd > you
and that model Celica doesnt make any power until 5.5k, has it always done this or did it just start?
sig under construction
Old Nov 20, 2006 | 08:58 AM
  #18 (permalink)
Jordan Y.'s Avatar
15 seconds EXHILARATION
So, it only sputters until 6k? Isn't that around the VVTi activation? I wonder if that has any significance.
Like people said above, check/replace plugs, wires, maybe the distributor/coil pack/whatever, crank angle sensor, fuel filter, fuel injectors, mass air flow meter or manifold pressure sensor, ecu, ecu codes, base timing, o2 sensor maybe, maybe something with the vvti as it seems to go away after vvti engages the aggressive settings, basically everything that could cause incorrect fuel or timing.
Describe the sputtering in more detail.
Old Nov 20, 2006 | 04:05 PM
  #19 (permalink)
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Because when TR's resident Toyota freak comes on and says how uncool a Toyota is...theres problems amiss!!
I cant say how bad they are since I havent driven one, but specs wise...its a Honda Celica....thats all..
ASE: Brakes
Old Nov 20, 2006 | 04:14 PM
  #20 (permalink)
JR.'s Avatar
JR.
check for low oil.
98 talon awd automagic
