Sr20
Old Oct 28, 2006 | 07:11 AM
Chris C.'s Avatar
I ♣ Baby Seals.
Originally Posted by kbprice
4AG = 1.6L
3S-GTE = 2.0L
5S-FE = 2.2L
2JZ-GTE = 3.0L
Damn, Toyota must be on the metric system or somthing...
Old Oct 28, 2006 | 07:48 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Or how about this....22R-TE....2.4...
One thing Toyota doesnt tell in their engine codes is displacement. Thats the only reason why Nissan's codes are better...also, Nissan will have two T's if its twin turbo, but even if there are 8 turbos on the Toyota, they'll only put one T
ASE: Brakes
Old Oct 28, 2006 | 12:35 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
ive never understod toyota codes, i think F in the engine code means it has one of the cams gear driven from another cam.
Old Oct 28, 2006 | 12:47 PM
TSX24L's Avatar
serioulsy?
Old Oct 28, 2006 | 01:28 PM
YARO's Avatar
Smith & Wesson Protected.
Toyota Engine Codes:
BEFORE "-":
the letters indicate the engine family, for example in 18R-G
the engine family is R, in 2JZ-GTE the family is JZ.
The number(s) at the beginning is the number of the are for a certain
bottom end version (block, bore, stroke). The larger the number,
the newer the bottom end version. It may seem like the larger the
number, the larger the displacement but this is not always true.
AFTER "-":
G = twin cam (wide angle, 45 degrees or more between the intake and exhaust valves)
F = "economical" twin cam (narrow angle, around 22 degrees)
T = turbocharged
Z = supercharged
E = fuel injection
i = single point fuel injection
L = transverse mounted engine (seems to be an obsolete code)
B = twin carbs (only used on non-twin cam engines, obsolete code)
R = air injection
S = swirl intake ports (only a few made in mid '80s)
S = direct injection & swirl pot pistons (starting from '97/9
U = emission package (Japan)
C = emission package (California)
LPG = LPG fuel
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
