Stripped head bolts...
Old Oct 18, 2006 | 07:44 PM
SmokinS13SR20's Avatar
That ginger...
Default Stripped head bolts...
What can be done?
Old Oct 18, 2006 | 10:34 PM
BAMF's Avatar
Thread TERRORIST
Vice grips? I figure you've already tried it, but thats the only way I know of. Normally I'd say fuck it, just drill the thing out with a good bit, but that would cause major problems in a head. If the bolt isn't seized up, a pair of vice grips shoudl do the trick. Unless its hardened, most vice grips will actually be able to compress the head of the head bolt where you squeeze it, giving you a little bit nicer of a surface to try and twist with. If you fail with them, the bolt is hosed, though.
"They were crying when their sons left, God is wearing black. Hes gone so far to find no hope, hes never coming back. They were crying when their sons left, all young men must go. Hes come so far to find the truth hes never going home."
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old Oct 18, 2006 | 10:41 PM
CrypticApathy's Avatar
OH SNAP!
HAHA!!! Glad to know ill never have that problem!
On that note... ive had a couple striped bolts taht i rounded out. if you are really careful you can take a small eletric drimmial and cut you a new head out of it by sanding down the circle to make a square. it takes time but it will be alot better on the engine then drilling through it.
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
Old Oct 19, 2006 | 02:32 AM
Chuck 98 RT/10's Avatar
Sexist
EZ out
On a related note, this penetrating oil is the best on the market. I've had a can of it for 20 years. Works awesome. All do-it-yourselfers and shops would do themselves a favor keeping a can of this stuff around.
Catalog Item Display
Please, don't anybody reply with "WD40", that stuff is worthless.
You can also find bolt extraction tools on that site.
Here is one example of an EZ out
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Old Oct 19, 2006 | 08:29 AM
P057's Avatar
isuck
+5, there are so many better products than WD40, I'll give chuck's stuff a try, I've been using a diff can of stuff.. cant remember the name though. blah i dont feel like going to the shed.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Oct 19, 2006 | 08:45 PM
BLUE2KSS's Avatar
Mechanical Engineer
EZ out
i personally like BG's Inforce for penetrating oil, havent found anything it hasnt helped on yet
Old Oct 19, 2006 | 10:48 PM
BLUE2KSS's Avatar
Mechanical Engineer
Originally Posted by Shinmei2006
Pb?
childs play compared to the above mentioned oils, but it works pretty good
and you can get it local without too many problems.
but your best bet is some sort of stripped bolt remover tool, unless it broke off inside, then drill it out is the best bet
Old Oct 20, 2006 | 06:44 PM
gtmike's Avatar
chisel and a hammer?Try and break the head off???
Old Oct 20, 2006 | 08:19 PM
That ginger...
No, Its a headbolt, kinda don't want to drill it out and retap it.
The head is warped, thats why I couldnt get it out, I'm thinking about trying the vice grips again, but welding it on there. So it doesnt matter what happens to the head.
