twin turbo
Old Sep 20, 2006 | 08:38 PM
Ronald Mcdonald's Avatar
Shakotan/Hippari life.
Originally Posted by Strokd85
Read a couple of posts up, the turbo'd Porche's are 6's...
I know that, but he was talking about the 4 cylinder ones not being an inline, and as i know that info already, i was just stating that they are still a 4 cylinder
-'03 GSX-R 750
Old Sep 20, 2006 | 09:47 PM
YARO's Avatar
Smith & Wesson Protected.
Twin turbo 4 cyl. FTL.. their's no point
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Old Sep 20, 2006 | 09:51 PM
Troux's Avatar
TT 4 cylinders are very doable, but not common because there aren't many (if any) kits out there to do so, and there isn't enough reason to offset the cost. Twin turbos have the benefit of better response and spool, and greater turbo life than singles, but are expense, and with most performance cars around here being only drag-focused, response isn't a factor. Also, the smaller the motor/turboes, the smaller the response benefits of a twin setup.
The cost (and extra weight, though mostly negligible) isn't worth it for most people, when they typically just have a simple HP goal, which can always be reached by a tried-and-true single, often available in a complete, cheap kit.
For the record, having two cylinder banks doesn't make it that much easier to have twins, as compared to an inline having twins, just makes it that much more sensible to have twins as opposed to a single on a multi-bank engine.
