MAF cleaner
Old Aug 3, 2006 | 07:12 AM
mrnicejetta's Avatar
farfromügen
I know CRC has an electrical connection cleaner (called electromotive or something like that) and an air intake cleaner (called air intake cleaner). Are you trying to clean the electrical connections or the sensor itself? Those would be the two.
on a side note, if you're using the air intake cleaner...
be sure to be away from any painted surfaces. That stuff will take paint off(along with all the carbon/sludge buildup it's supposed to) like melting butter. I found that out on a painted intake mani I had.
Der schnellste mann im langsamsten auto
Old Aug 3, 2006 | 07:24 AM
farfromügen
The air intake cleaner should work just fine. But whatever suits your fancy. Those were the only two that came to mind.
Old Aug 3, 2006 | 07:40 AM
farfromügen
Use the part number CRC-05110 and just call around.
Old Aug 3, 2006 | 07:46 AM
farfromügen
That's cool. The last time I spoke with someone at Pepboys they didn't know what a triple square/ 12pt star bit was, or where to find one. I ended finding one at NAPA, you might try them as well if they're closer
