engine/car formulas
alright i figured this would be a good thread to start..its so every one in here can just post formulas they know for figureing engine/car stuff out.
1.how to figure out your cubic inches . bore x bore x stroke x .785 x number of cylinders= your cubic inches. example 4.00 x 4.00 x 3.48 x .785 x 8 = 349.67 witch is a chevy 350 2.how to figure out your cam over lap int duration + exh duration / by 4 - lobe x 2 = valve over lap example 285 + 292 / 4 - 112 x 2 = 64.5 3.calculating how much cfm your engine will use(for carb selection) engine cubic inches x max rpm / 3456 = cfm example 355 x 8500 / 3456 = 873 4.et calculating stuff your 1/8 mile time x 1.5832 = 1/4 time your 1/4 mile time / 1.5832 = 1/8 time TUEBO STUFF 5.on a turbo map ever 10lbs =144.72 cfm 6.figuring out pressure ratio from boost atmospheric pressure at sea level is 14.7 psi so 14.7 + amount of boost / 14.7 = pressure ratio example 14.7 + 34 / 14.7 = 3.3 7.figureing out your engine volumetric flow or EVF in cfm. step 1 engine ci / 1428 = step 2 engine rpm / 2 = step 3 take step 1 answer and times it by step 2s answer witch will give u your evf. 8.figuring out your engines airflow in lb/min step 1 your psi u plan on running x your evf x 29 = step 2 10.73 x 460 = step 3 take step 1s answer and div it by step 2s witch then u get your engines airflow in lb/mins |
lol tony, you got everyone speechless
yeah i guess no one has anything to add to it..i was hoping this might become a good sticky for on here
sticky
Brake Math
-it's all about the square inch area of the master cylinder pushing against the square inch area of the caliper piston. -Then you have a ratio between the pedal to the pivot length, and from the pivot to master cylinder rod length. -If you had a 2" diameter piston in one caliper you have 3.1416 square inches of area. -If you have a master cylinder that is 1" diameter you have .7854 square inches of area. -So you take 3.1416, divide by .7854 and you get a hydraulic ratio of 4:1. -This means that if you could get a pressure at the master cylinder rod of 180 pounds you get 180 times 4 or 720 pounds of force at the caliper piston. -You can get the 180 pounds at the master cylinder pushrod by having a 9" long brake pedal arm hanging down, with the top end mounted say about 3" above the master cylinder piston, a pivot for the master cylinder rod clevis at 3" from the top, and then 6 inches from that pivot down to a foot pedal. -the 6" divided by the 3" is a 2:1 ratio meaning that if you moved the foot pedal two inches you'd push the master cylinder rod 1". -So to get 180 pounds at the master cylinder rod you'd need to push 90 pounds of push from your foot on the brake pedal. |
Formulas for Various Computations
Key; * Pi = 3.14159 * F = Degrees Farehenheit * C = Degrees Celsius (Centigrade) * R = radius ( When preceeded by degrees F or degrees C, it refers to Absolute temperature [Rankin]) * D = Diameter Weights: * 1 Gallon of Oil = 7.0 lbs. * 1 Gallon of Water = 8.354 lbs. @ 60 deg.F. * 1 Gallon Gasoline = 6.2 lbs @ 60 deg.F. * 1 Gallon Alcohol = 6.616 lbs @ 60 deg.F. * 1 Gallon Nitro = 9.505 lbs @ 60 deg.F. Conversions; * Cubic Inches to Gallons = Divide by 231 * Gallons to Cubic Inches = Multiply by 231 * Cubic Inches to Ounces = Multiply by .554 * Ounces to Cubic Inches = Divide by .554 * * Cubic Centimeters to Cubic Inches = Multiply by .06102 * Cubic Inches to Cubic Centimeters = Multiply by 16.39 Circles: * Area of a Circle = Pi x R ^2 (3.14159 x R^2) * Area of a Circle = .7854 * D * * Circumference of a Circle = 2Pi x R (6.2832 x R) * Circumference of a Circle = Pi x D Temperature: * Absolute Zero = -459.7 deg. F. * Absolute Zero = -273.2 deg. C. * * Absolute Temperature deg. F. = deg. F. + 459.7 ( May be rounded to -460) * Absolute Temperature deg. C. = deg. C. + -273.2 (May be rounded to -273) Jet Change for Fuel Injection * New Air Density - A * Old Air Density - B * Current Jet.... - C * Formula; (A-B)/ (B) x 100 = % Change in Density * Sqrt(((C/2)^2(PI)(-(A-B)/(B))/(C/2)^2(PI))/(PI))x2 = New Jet Size. Fuel Delivery in GPM @ RPM Lbs.Fuel @ RPM -------------- Weight of 1 Gallon Fuel. Lbs Fuel @ RPM Lbs. Air@RPM ------------ Desired A/F Ratio Lbs Air@RPM CFM @ RPM x Weight of 1 cu.Ft Air Weight of 1 Cu.Ft. Air 1.326 x Barometer Rankine= Temp Deg F +460 |
Piston speed:
stroke in inches x rpm/6=fpm Blower Capacities: Sizes and capacity are:- 6:71 small diameter Rotor dia=5.505", length=14.975", displacement per full turn of rotor=339CI. 6:71 big diameter Rotor dia=5.778", length=14.975", displacement per full turn of rotor=411CI. 8:71 Rotor dia=5.778", length=15.905", displacement per full turn of rotor=436CI. 10:71 Rotor dia=5.778", length=17.000", displacement per full turn of rotor=466CI. 14:71 Rotor dia=5.778", length=19.000", displacement per full turn of rotor=521CI This is theoretical displacement. Retro or high helix will change this considerably. A worn blower will reduce this a little. A very good tight new blower and a Teflon stripped blower should be about the same Supercharger plenum size: surmising an engine size of 202 6 cyl (you put your own numbers in here) Inlet air density ratio of 1.55. Eg; 202/6= 33.6666 x 1.55= 52.183333. Air cushion of 3 times cylinder volume is needed. So 52.183333 x 3= 156.54999 cubic inches for CC's times this figure by 16.387 = 2565.3848 Air Density Index ADI = 100 * [ (PBAR-PWV) / 29.92 ] * [ 519.67 / ( 459.67 + T ) ] PBAR = Barometric Pressure (inches Hg) PWV = Water Vapor Pressure (inches Hg) T = Temperature (deg Fahrenheit) |
Fuel Requirements
Engine CID x RPM/3456=CFM CFM x air denstiy x Volumetric effeciency=ACFM ACFM x .07416= WOA WOA/desired a/f=Fuel needed in lbs |
Plus if anybody needs em ive got everything from piston kinematic programs, to enderle and hilborn conversion charts, to nitro mixing and tuning charts, Dynamic CR calcs, valvetrain timing/geometry .....yadayadayada
