fix poly-urethane?
i got a 180 type x bumper and it's cracked in a couple spots. is there anything that i can use to fix the cracks. not going to fibergalss b/c it is to stiff and will crack. does anyone know of any products to use for poly-urethane?
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Home Depo sells polyeurethane under the disguise of Chimney seal
or some similar name. Big caulking gun tube. Worth a try, maybe.-Bob
Let us know if you try/if it works.
your best bet would be to squirt it out onto something flat and get a small putty knife, or those little plastic things that they give you to put decals on, and spread it on with that, and do it like bondo sortof, it wouldn't work to well if you used it like normal caulk
