Grinding :(
Old Jun 20, 2006 | 07:17 PM
Ringo_'s Avatar
Default Grinding :(
okie so when iam going i get in second gear fine and then when i go to 3rd some times it just stops and wont go in gear so i have to throw it in 4th and other times going into 3rd it will stop and grinds...do i just need a new clutch or messed up tranny or what
Old Jun 20, 2006 | 07:24 PM
mrnicejetta's Avatar
farfromügen
3rd gear synchro. Depending on what kind of car you have, it might help when you're going to third(either up or down) to:
1. shift to nuetral, let out clutch
2. put in the clutch, and slowly ease in to third.
In the meantime investigate how much work is involved in swapping out the synchro. Also, if you have a short shift kit try to locate the original linkage/cable to revert it to stock.
Der schnellste mann im langsamsten auto
Old Jun 20, 2006 | 07:46 PM
Ringo_'s Avatar
gota h22...hydro clutch if that matters..i dont really know much iam still a newbie tryin 2 learn
Old Jun 20, 2006 | 07:48 PM
farfromügen
Shouldn't matter. If the master or slave cylinders were going out it would do it in all gears. The only thing I could think it could be would be the synchro.
Old Jun 20, 2006 | 11:04 PM
Hater's Avatar
Free base cocaine
^if the master slave was out the clutch woulnt work very well at all, i think hes right on with the synchro
Old Jun 21, 2006 | 04:27 AM
+1 on the synchro.-Bob
Old Jun 21, 2006 | 02:46 PM
jlude90's Avatar
aspiring luder
same thing in my prelude, it sucks like a mofo, except mines in first, and second is going too, but...an H22 will fix that, best i can say is go slow in the gears, and don't romp on it too much
Old Jun 21, 2006 | 04:35 PM
Road Rage's Avatar
Shake n' Bake
Take it to a tranny shop it could be anything from the tranny to the linkage, you wont get it answered correctly on the internet......
Old Jun 21, 2006 | 05:16 PM
ImportLuv's Avatar
^ most shops would say "well we have to remove the transmission from the car to see what's broken or needs replacement" When the "gates" in the gears isn't smooth, 99% of the time, it's the syncos that is wearing out.
Don't expect removing the transmission is no charge.
I drive my car grinding the gears sometimes when letting the clutch out all the way.
Cause: Bad synco bearings
Note: Also check to see if your clutch is let out all the way. Adjust it if it's not out all the way.
