question bout boost controlers
Old Jun 5, 2006 | 08:19 PM
RussianKid's Avatar
NA > Turbo
Default question bout boost controlers
whats the difference between...
*Gain
*Set
*Set Gain
Old Jun 5, 2006 | 08:59 PM
LynxZ3r0's Avatar
///M Roady
A Very Good Profec B Tuning Guide
I assume you're using a GReddy, anyways.. since those are the "confusing" settings on it.
Be careful using the default settings that website offers, unless you drive an Evo. Start w/ your set at 0% and work your way up to desired boost.
Old Jun 5, 2006 | 09:04 PM
RussianKid's Avatar
NA > Turbo
i know how to use it. but wtf do those settings do?
i just use SET to change boost.
but then theres GAIN which goes up tp %100 and SETGAIN which come up to 425 i think.
%100 of what
425 of what?
i noticed that when i change those numbers...
a) turbo spools up quicker
b) boost storts droping at highr rpms
c) all of the above
Old Jun 5, 2006 | 09:17 PM
RussianKid's Avatar
NA > Turbo
Originally Posted by LynxZ3r0
didnt notice the link at first.
great link. i found out everything i wanted.
thank you.
LynxZ3r0's Avatar
///M Roady
Well... the tuning guide roughly describes what they do.. but..
Gain: Basically this sets the rate at which the boost controller allows the boost to increase past the wastegate spring. The higher you can run it w/o overboosting/spiking, the better, but this number usually ends up pretty low for everyone.
Set Gain: This is the lowest point at which the EBC will begin to increase boost under WOT. You want this as close to your "Set" value as possible without overboosting/spiking.
Edit: And no problem You beat me to the reply button.
Old Jun 5, 2006 | 09:22 PM
RussianKid's Avatar
NA > Turbo
so if i want to do 15psi i need to set SETGAIN at 150?
Old Jun 5, 2006 | 09:33 PM
LynxZ3r0's Avatar
///M Roady
Not always. Chances are that if you do that, you'll spike to about 18-20psi.
I'd say start with a Set Gain of about 100 (10psi) and then observe your boost gauge. If boost seems to fall off at higher RPMs, then increase the Set Gain.
Old Jun 5, 2006 | 09:42 PM
RussianKid's Avatar
NA > Turbo
i set it at 150, and it falls of over 4500, by the time i get to 7800 im at 10psi
Old Jun 5, 2006 | 10:04 PM
LynxZ3r0's Avatar
///M Roady
What is your Gain set at?
Old Jun 5, 2006 | 10:17 PM
RussianKid's Avatar
NA > Turbo
set 38
gain 42
sg 150
