could this be the problem?
i installed my motor and it had a knocking sound that would rise with rpm. it sounded like it was coming from the head, but i couldn't pinpoint it. also it had a small oil leak down by the pan. i decided to pull the motor back out and tear it down again to see what was going on, and to fix the leak. i got the motor out, and while i was pulling off the clutch, i noticed that about half of the fingers on the pressure plat were slightly bent inward and had a small groove on them. i looked down at the t/o bearing and it looks just fine. i used an alignment tool when putting it on. i never did listen for the noise with the clutch pedal depressed, but i probably should have. anyone got any ideas of wheather or not this could be the problem, or what i did wrong on the clutch install? i've installed many, many clutches in the past with zero issues
91 ranger, 88 tc 2.3 turbo, stroked, bored, 5.5" crower connecting rods, wiseco 8.0:1 dished pistons, total seal .030 rings, fully ported iron big valve head, racer walsh turbo roller cam, bobs log, holset wh1c, fmic, full 3" exhaust. not really a whole lot left to do.
93 explorer 4x4
93 explorer 4x4
This might sound stupid, but on your car how do you tell if the disc is facing the proper direction? -Bob
it would cause it to chatter and ware alot faster if facing the wrong way.check the spacer between the block and transmission,alot of times those bend in reinstalling the tranny and rub against the flywheel.
