engine cleaner/additives etc....
ok guys just got a 92 corolla from down in miami. the oils look a little more than brown so am gonna go ahead and change the oil. i wanted to know if there are any engine additives or anything similiar that would make a difference and help remove sludge and any other deposits. i see prolong and others in stores. which if any can i use to i guess "clean" out any potential sludge that may be deposited in there. lmk
If you break loose the sludge, it might be a good idea to change filters REALLY often until
it gets out the chips. Sometimes a person is better off to leave the crud sticking to the walls instead of setting it loose where it can clog passages and get to bearings.
I also put a strong magnet on my filters to catch metal "dust".-Bob
i don't know if this is what your talking about or not, but i use engine restore every oil change, it is a noticeable difference, and cheap too, but its for filling small imperfections in the walls and stuff, not so much cleaning i guess
http://www.atvconnection.com/atvconn...e-Restorer.cfm
hope this helps/is what your looking for
Justin
Justin
bump on the restore
Wants the old SSA^ back crew member #001
B³ member(Bikes, Beer and Boobies)
98% of teenagers drink alcohol or have been around alcohol. Put this in your profile if you like ducksauce.
that's how you know it's ready for new oil
The only engine cleaner that I have never seen someone not approve of is water.
Seriously.
Seriously.
ASE: Brakes
ASE: Brakes
