A/C System Troubleshooting
Old Apr 21, 2006 | 10:37 AM
aaron1017's Avatar
is not Rotarded anymore!
Default A/C System Troubleshooting
Alright, my g/f's brother's car is having A/C system trouble.
He says the A/C takes a long time to blow cold. Then gradually it blows less and less cold, never getting cold again in the time they drive the car.
The dealer says the compressor is fine and they want to flush the system?
Do you feel this could be the problem? Or should I sell them to check the pressure switches first?
LS1/T56 Heads Cam 1994 FD
Old Apr 21, 2006 | 10:05 PM
BigSteve's Avatar
AKA: Captain Low Ball
might be the expansion valve, also u might want to change the drier at the same time....
Old Apr 22, 2006 | 08:27 AM
BigBadBuick's Avatar
Livin' Large
Yep, I'd definitely tell the dealer to check the pressure switches. When they look at you funny and say, "where did you come up with that?" tell them BigBadBuick on TampaRacing.com said so.
Old Apr 22, 2006 | 09:13 AM
Young,Fablous,&Broke's Avatar
When is the last time you had the A/C bearings replaced?
Old Apr 22, 2006 | 12:29 PM
Livin' Large
Something tells me that if the dealer did truly check it they a.) checked the pressures, and b.) know there is nothing wrong with the pressure switch/switches. If they diagnosed the problem without checking the pressure readings, take it someplace else.
Old Apr 22, 2006 | 02:46 PM
gtmike's Avatar
have them run a vacuum test.
Old Apr 24, 2006 | 05:19 AM
Livin' Large
And tell them 'gtmike' on the internet recommended it This is fun.
