turbo and centrifical supercharger ??
alright a centrifical makes more boost faster your engine rpms go right?? so at idel u may be like 3psi but at your red line point u would be at 20 or what ever right.
and a turbo once it fully spools its at the max boost level u want right?? so u may be like 3 but once it hits 3grand its at max boost tell your red line.
i'm just trying to figure out something
-Vince
-Vince
Guest
Posts: n/a
Originally Posted by GsEclipse02
full boost at idle? i dont think so ... explain
or maybe he meant using a teenie weenie turbo..... i.e. the one you had on your GS
Originally Posted by Kirk
I believe he means off the line... only way to build boost with no load on the motor would be with a 2step
he said at idle ...
Guest
Posts: n/a
\^/3ll 4 c3|\|7|21fug4l 15 |\|07 g01|\|g 70 c|23473 b0057 47 1dl3. 7h3y 5p00l ju57 l1k3 4 7u|2b0 d035... h0\^/3v3|2, 7h3y |\|3v3|2 570p "5p00l1|\|g". 1|\| 7h30|2y, 4 100mm 7u|2b0 \^/1ll 5p00l up f4573|2 7h4|\| 4 c3|\|7|21fug4l 5up3|2ch4|2g3|2 0f 4|\|y 51z3 - b/c 7h3 c3|\|7|21fug4l bl0\^/3|2 |\|3v3|2 |234ch35 4 74|2g37 b0057 53771|\|g.
70 4|\|5\^/3|2 y0u|2 qu35710|\|, y0u'd |\|33d 70 k|\|0\^/ m0|23 7h4|\| ju57 7h3 7u|2b0 51z3, bu7 4l50 3|\|g1|\|3 51z3 4|\|d \^/h47 c0|\|f1gu|24710|\|
also look at torque... a centrifugal S/C wont make anywhere near the torque of a roots blower or twin screw... it will make torque linearly, just like its HP, till you hit the max boost the pulley will allow... usually at high rpm's... a big factor if your motor has low displacement.
a turbo will always make more torque and make it much early in the powerband...
Happiness isnt around the corner...Happiness is the corner
http://www.racingdynamics.com/
I dunno if this is useful or not, but pretty much all of the 8000hp drag cars use lysholm s/c's (almost like a whipple), not turbos. Granted you probably don't want to be running 40+ psi on a monster V8. I just wanted to illustrate the point.
Der schnellste mann im langsamsten auto
