vtec
Old Mar 5, 2006 | 07:02 PM
sprayou101's Avatar
Default vtec
http://images.google.com/imgres?imgu...lr%3D%26sa%3DG
Old Mar 5, 2006 | 07:08 PM
dohcvtec's Avatar
You boys like Mexico!!!
DOHC VTEC > ALL
Nice find
Springhill
22" Nothing less
Old Mar 6, 2006 | 06:54 AM
F*r*a*n*k*e*i's Avatar
According to this article, it appears that VTEC CAN NEVA LOOZE!!
Old Mar 6, 2006 | 08:15 AM
OniS14's Avatar
do it BIG!!
VTEC is one of Honda's greatest invention.
BULLSH*T!
that's like saying mazda invented rotary!
Thus Honda invented VTEC which allows it to extract turbo level specific output from its engines without having to suffer from the disadvantages of turbocharging (though VTEC introduces disadvantages of its own).
bullshit..nissan had it way before..and honda refined it.
disadvantages of turbocharging? har har harrrr
vtec is good for small go-kart like cars...too bad it doesnt work for bigger cars..
i havnt seen your NA power win anything in JGTC..hehehe
honda's best implementation of vtec is its NSX...which is basically a toned down Nissan MID4..
Nissan MID4 = 1985
Honda NSX = 1990
know your origin..honda kids..
the present is useless if you dont know the past..
https://www.tamparacing.com/forums/v...ml#post2932660
History
The first experimentation with variable valve timing and lift was performed by General Motors. GM was actually interested in throttling the intake valves in order to reduce emissions. This was done by minimizing the amount of lift at low load to keep the intake velocity higher, thereby atomizing the intake charge. GM encountered problems running at very low lift, and abandoned the project.
The first functional variable valve timing system, including variable lift, was developed at Fiat. Developed by Giovanni Torazza in the 1970s, the system used hydraulic pressure to vary the fulcrum of the cam followers. The hydraulic pressure changed according to engine speed and intake pressure. The typical opening variation was 37%.
The next big step was taken by Honda in the late 1980s and 90s, where Honda began by experimenting with variable valve lift. Pleased with the results, engineers took the knowledge and applied it to the B16A engine, fitted to the 1989 EF9 Honda Civic. From there it has been used in a variety of applications, from sport to utility, by many different auto makers.
In the year 1992, BMW introduced VANOS, their version of a variable valve timing system, on the BMW M50 engine used in the 3 Series. VANOS significantly enhances emission management, increases output and torque, and offers better idling quality and fuel economy. The latest version of VANOS is double-VANOS, used in the new M3. Double-VANOS adds an adjustment of the intake and outlet camshafts.
One thing that separates the BMW variable timing from what Honda developed is that VANOS provides stepless adjustments to the valve timing throughout a rpm regime to provide optimum timing at all engine speeds within that regime. Honda's VTEC triggers a single step change at in the timing when the engine speed reaches a preset rpm (this rpm occurs near high rpm ranges).
Variable valve timing was the sole domain of overhead cam engines until 2005, when General Motors began offering the LZE and LZ4, pushrod V6 engines with VVT. For the 2006 model year, General Motors will introduce the Vortec 6200, the first mass-produced pushrod engine with variable valve timing.
sr20_NOS_hoe ...your turn to chime in
dont get me wrong...valve timing is cool..its just not honda..
S14 parts f/s
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
Old Mar 6, 2006 | 08:29 AM
OniS14's Avatar
do it BIG!!
Originally Posted by Cronic
Who cares? On all counts. I've read that before, read most of ToV before... and Im not sure why you've posted this.
I dont see why it matters who invented varaible valve timing (VVT)? Honda is known for it, in all circles of the world. It's like saying the US invented war, just because the world knows us for it.
no...cavemen w/ pointed sticks and rocks invented war..
S14 parts f/s
Old Mar 6, 2006 | 10:33 AM
Road Rage's Avatar
Shake n' Bake
:yawn:
Old Mar 6, 2006 | 10:46 AM
OniS14, there's one thing you totally forgot...
VTEC CAN NEVA LOOZE!!!
Old Mar 6, 2006 | 01:00 PM
Hater's Avatar
Free base cocaine
wtf is the vtech temple?!?
Old Mar 6, 2006 | 01:07 PM
OniS14's Avatar
do it BIG!!
har har har! i loose to teh vtak!
well..i was mowing the lawn with this husqarvarna[sp?] lawnmower and this honda mower comes out of nowhere! man..that vtak kicked in and it was all over! grass clippings all over the place!
today's lesson:
never compete with a honda when it comes to cutting grass!
S14 parts f/s
