programming viper alarm!
I don't know exactly how off the top of my head, but I do remember searching the web for the instructions and someone had a pdf with the viper instructions. I think the user manual is available at the dei homepage just not the install guides. I know it starts with open door, turn on ignition, push valet button ( a certain number of times), hold button on last press and siren will chirp to confirm the number selection, then press the lock button ( or any other button that can be assigned to the channel that you select). Repeat for other buttons on a custom setup or if using the quick learn just one button needs to be programmed into a specific channel and the alarm will run on the default programming. If I get a chance to look at my viper install book I'll let you know.
