Domestic or rather GM engine codes
Old Dec 8, 2005 | 09:44 AM
F*r*a*n*k*e*i's Avatar
Good deal!
Old Dec 8, 2005 | 09:52 AM
The Ford info was actually really helpful to me. I've got that 351C now and it confuses the fuck outta me as to what parts fit where. Fords aren't quite as interchangable as the old Chevy motors
Old Dec 8, 2005 | 10:08 AM
myltwon's Avatar
Bolt-On 2v GT
Originally Posted by John
still there is no designation for differences in the motors.
the LT prefix indicates GEN II
the LS prefix indicates GEN III
for the most part, it's not as concrete as other manufacturers
though there was a GEN I "LS6" in the chevelle ss
Old Dec 8, 2005 | 10:19 AM
B18C5-EG's Avatar
Originally Posted by Mars_302
But no-one listens to him . Cool find
Old Dec 8, 2005 | 10:23 AM
Half Fast's Avatar
LT1's are slow!
I guess I should say engine codes for GMs are also based on their RPO or build codes. There was a Gen I LT1 as well as the Gen LT1
The codes are similar but different. A Gen. I would be an LT-1, a Gen. II is the LT1 or LT4. (Which do share many internal parts with Gen I BTW)
And with the BB's it was an LS-6 as opposed to the Gen. III LS6
Richard
1996 Corvette CE coupe LT1/A4
Mostly stock
1998 Camaro
Z28 badges and dual exhaust tips
Most detailed engine information, Ford or Chevy, is in the VIN or option sticker. You can also decode the casting # on the engine to gain some details about it, or the casting # on the heads. An LS1 is just a designation for displacement,bore, and stroke. Both the LT1 and LS1 are ~350 cubes, but they're totally different geometry.
http://www.mortec.com/borstrok.htm
262 = 3.671" x 3.10" (Gen. I, 5.7" rod)
265 = 3.750" x 3.00" ('55-'57 Gen.I, 5.7" rod)
265 = 3.750" x 3.00" ('94-'96 Gen.II, 4.3 liter V-8 "L99", 5.94" rod)
267 = 3.500" x 3.48" (Gen.I, 5.7" rod)
283 = 3.875" x 3.00" (Gen.I, 5.7" rod)
293 = 3.780" x 3.27" ('99-later, Gen.III, "LR4" 4.8 Liter Vortec, 6.278" rod)
302 = 4.000" x 3.00" (Gen.I, 5.7" rod)
305 = 3.740" x 3.48" (Gen.I, 5.7" rod)
307 = 3.875" x 3.25" (Gen.I, 5.7" rod)
325 = 3.780" x 3.622" ('99-later, Gen.III, "LM7" 5.3 Liter Vortec, 6.098" rod)
327 = 4.000" x 3.25" (Gen.I, 5.7" rod)
346 = 3.900" x 3.622" ('97-later, Gen.III, "LS1", 6.098" rod)
350 = 4.000" x 3.48" (Gen.I, 5.7" rod)
350 = 4.000" x 3.48" ('96-'01, Gen. I, Vortec, 5.7" rod)
350 = 3.900" x 3.66" ('89-'95, "LT5", in "ZR1" Corvette 32-valve DOHC, 5.74" rod)
364 = 4.000" x 3.622" ('99-later, Gen.III, "LS2", "LQ4" 6.0 Liter Vortec, 6.098" rod)
383 = 4.000" x 3.80" ('00, "HT 383", Gen.I truck crate motor, 5.7" rod)
400 = 4.125" x 3.75" (Gen.I, 5.565" rod)
427 = 4.125" x 4.00" (2006 Gen.IV, LS7 SBC, titanium rods)
Two common, non-factory smallblock combinations:
377 = 4.155" x 3.48" (5.7" or 6.00" rod) 400 block and a 350 crank with "spacer" main bearings 383 = 4.030" x 3.75" (5.565" or 5.7" or 6.0" rod) 350 block and a 400 crank, main bearing crank journals cut to 350 size
www.mortec.com has a TON of shit on GM casting #'s too. Decoding an old 60's Chevy is a big pain in the dick. Trust me, I know.
