how many people would honesly drive this
http://bosshoss.com/view_bike.asp?x=...25984616.91381
Engine
Type
Liquid Cooled V-8
Horsepower
502
Torque
567
Block
Cast Iron - 4 bolt main
Cylinders
Aluminum (110cc)
Valvetrain
2.25"Int. / 1.88"Exh
Size
502 c.i. (8200cc)
Compression
9.6:1
Carburetor
Quadrajet 850 cfm
Exhaust
2.5" with dual mufflers
Transmission
3-speed semi-auto w/rev.
Final Drive
Shaft, narrowed Ford 7.5" (open)
Dimensions
Wheel Base
83.5"
Seat Height
29.0"
Rake
33.0 degrees
Grd. Dlearance
6.5"
Frame Width
60.0"
GVWR
2093 lbs.
Dry Weight
1700 lbs.
Tires/Wheels
Front
130/90-16, 3.50"x16.0"
Rear
275/60R-15, 10.0"x15.0"
Suspension
Front
60mm inverted forks, adj. preload 2.5" travel
Rear
Dual 17" coilover shocks, single 17.5" rebound damper, adj. preload
Brakes
Front
Dual four-piston calipers, 12.6" floating disc
Rear
9.0" drum brakes
Fuel
Tank
8.5 gal.
Reserve
3.5 gal.
High/Low MPG
18/13
Engine
Type
Liquid Cooled V-8
Horsepower
502
Torque
567
Block
Cylinders
Aluminum (110cc)
Valvetrain
Size
502 c.i. (8200cc)
Compression
9.6:1
Carburetor
Quadrajet 850 cfm
Exhaust
Transmission
2-speed semi-auto w/rev.
Final Drive
Belt, Gates- Polychain
Dimensions
Wheel Base
82.0"
Seat Height
28.5"
Rake
33.0 degrees
Grd. Dlearance
4.5"
Frame Width
31.0"
GVWR
1827 lbs.
Dry Weight
1300 lbs.
Tires/Wheels
Front
Rear
230/60, 7.0"x15.0"
Suspension
Front
Rear
Dual 13.0" coilover shocks, adj. preload
Brakes
Front
Rear
Single four-piston caliper, 12.6" floating disk
Fuel
Tank
8.5 gal.
Reserve
n/a
High/Low MPG
18/13
Engine
Type
Liquid Cooled V-8
Horsepower
502
Torque
567
Block
Cylinders
Aluminum (110cc)
Valvetrain
Size
502 c.i. (8200cc)
Compression
9.6:1
Carburetor
Quadrajet 850 cfm
Exhaust
Transmission
Final Drive
Dimensions
Wheel Base
83.5"
Seat Height
29.0"
Rake
33.0 degrees
Grd. Dlearance
6.5"
Frame Width
60.0"
GVWR
2093 lbs.
Dry Weight
1700 lbs.
Tires/Wheels
Front
Rear
Suspension
Front
Rear
Brakes
Front
Rear
9.0" drum brakes
Fuel
Tank
8.5 gal.
Reserve
3.5 gal.
High/Low MPG
18/13
Engine
Type
Liquid Cooled V-8
Horsepower
502
Torque
567
Block
Cylinders
Aluminum (110cc)
Valvetrain
Size
502 c.i. (8200cc)
Compression
9.6:1
Carburetor
Quadrajet 850 cfm
Exhaust
Transmission
Final Drive
Dimensions
Wheel Base
82.0"
Seat Height
28.5"
Rake
33.0 degrees
Grd. Dlearance
4.5"
Frame Width
31.0"
GVWR
1827 lbs.
Dry Weight
1300 lbs.
Tires/Wheels
Front
Rear
230/60, 7.0"x15.0"
Suspension
Front
Rear
Brakes
Front
Rear
Fuel
Tank
8.5 gal.
Reserve
n/a
High/Low MPG
18/13
i wouldn't rock it but i think its faster then your car hehehehehe
Like us on facebook
Like us on facebook
I seen one get sideways on Columbus and Dale Mabry one night,a I/H/E/C V8 motorcycle is a very very very nasty thing.
R.I.P Pablo "Fathead" Garcia & Kevin "Slo_Si" Gonzalez Forever in our hearts.
