If you could make a car....
What would it be like? Would it be a 4wd subura and eclipse or something like that?
If I were to make a car and I mean from scratch I had whatever a billion dollars. I think I would make like a mid engine 4cylinder ( I would take maybe a toyota or honda engine) put it in there and have it easy to work on cause I dont know to many mid engines that are eays to work on... and have it handle like a dream with like and have the weight down to like 1800lbs with the help of carbon fiber and other composites and have around 180+ hp.
I think that would be a pretty sweet ride
RWD 2.4T making around 230-250HP in a small light roadster type car.
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Mazda 2 Forums
i just wish they could make 93-95 rx-7's brand new......like a 2006 rx-7, but look the same, but instead of 255hp maybe 350......i love them, or maybe them with an ls1 motor, ooh pure sex....
- Officially Retired....for now...
c6 carbon fiber body,tube chassis,lenco 5spd trans,brodix aluminum 350 main block with raised cam and 4.155 bore with a 4.25 bryant billet cranks,carrillo rods using honda jurnals.arias custom pistons,sb2.2 heads with tit valves and springs,custom made sheet metal intake with custom fuel injection setup,twin 76mm turbonetics turbos.custom done light weight intercooler,carbon fiber wheels.275s front and 335 in the rear.carbon fiber breaks.car would tip the scales around 2200 pounds and make around 1600h.p on pump gas.top speed would be depending on how big of balls you got.
super lightweight mid engine 2 seater...aluminum chassis..carbon fibre body..and ROTARY POWERED! light, simple, fun
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
