plug wires????
I change my plugs and wires every 20K miles. Champion plugs, stock wires.
Hi performance plugs and/or wires might cause static on the radio.
Chuck
www.BabelMotorsports.net
www.SAFEMotorsports.com
Chuck
Until you start doing some serious modifying to the motor, stick with stock, they are designed for the car to run well and efficiently stock. Once you start doing some serious modifying, then in order to handle more pressure, you will need to upgrade your ignition system. That's when you look into high charge wires, plugs, coil, ignition module, etc. Good luck
Originally Posted by Grangalan
Nology Hotwires are damn nice if you wanna pay 160 bucks. each wire has its own resistor built in which holds and amplifies the distributor charge..makes one hell of a spark
These are the biggest waste of money you could find for plug wires, they ground themselves out because of the transistor and no longer work.
SUCH IS THE RULE OF HONOUR.
