View Poll Results: A/C
Voters: 22. You may not vote on this poll
A/C: Recirculator Button or NOT!
Max A/C is the same as recirculate
The only cars I've driven that may have used the system you describe are fords and some chevys. I know that fords have an "ac" and a "max ac" setting on the knob, and the difference may well have been recirculation. It's been a while since I've driven one.
Also, I avoid using the recirculation button unless the AC isn't capable of blowing cold enough without it or if I'm stuck behind a smelly truck, in an industrial area, etc. Supposedly, recirculating the same air can allow carbon monoxide to build up in the cabin causing headaches and sleepiness. I think you have to have an exhaust leak or a path for exhaust to rise up into the car for it to happen, but I always experienced headaches and sleepiness on long drives with recirc ac in my old Accord, and after I stopped using the recirc those problems went away.
Originally Posted by Jordan Y.
Are you referring to a specific car?. Most of the cars I've driven have an AC button, a Recirc button, a fan speed control and a temperature control. You can set the fan speed to max, the temperature to the coldest setting, and have the AC on cooling outside air. When you press recirc, it starts drawing air from inside the cabin.
If a car does not have a recirculate button, max A/C pulls air from inside the car (recirculates), and regular A/C or the "norm" setting pulls outside air.
your what??? oh the word i was looking for was..... SLOW lol
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
KJ built
ALPHA TUNED
my car's a sauna with its black vinyl convertible top. but after two minutes of a/c on recirculate, i can hang slabs of beef in the back seat.
"The genius of any slave system is found in the dynamics which isolate slaves from each other, obscure the reality of a common condition, and make united rebellion against the oppressor inconceivable." ~Andrea Dworkin
"If... the machine of government... is of such a nature that it requires you to be the agent of injustice to another, then, I say, break the law." ~Henry David Thoreau, 1849
That's right, bitches, TWO quotes!
