what is the differences in premium and regular gas grades..?
Old Jun 13, 2005 | 04:10 PM
thereturnofdark's Avatar
Obama made me Republican
Default what is the differences in premium and regular gas grades..?
just as the title says, about a month ago i started putting only the most expensive gas in my car which is the premium, premium plus, ultimate, whatever you want to call it and my car seems to get a little better gas mileage. i was wondering if there were any guys on here that could give me a solid technical reason as to why this gas is more expensive, is it worth it and such.
Old Jun 13, 2005 | 04:47 PM
Country Boy's Avatar
can survive...
What do Fuel Octane ratings really indicate?
6.1 Who invented Octane Ratings?
Since 1912 the spark ignition internal combustion engine's compression ratio
had been constrained by the unwanted "knock" that could rapidly destroy
engines. "Knocking" is a very good description of the sound heard from an
engine using fuel of too low octane. The engineers had blamed the "knock"
on the battery ignition system that was added to cars along with the
electric self-starter. The engine developers knew that they could improve
power and efficiency if knock could be overcome.
Kettering assigned Thomas Midgley, Jr. to the task of finding the exact
cause of knock [24]. They used a Dobbie-McInnes manograph to demonstrate
that the knock did not arise from preignition, as was commonly supposed, but
arose from a violent pressure rise *after* ignition. The manograph was not
suitable for further research, so Midgley and Boyd developed a high-speed
camera to see what was happening. They also developed a "bouncing pin"
indicator that measured the amount of knock [9]. Ricardo had developed an
alternative concept of HUCF ( Highest Useful Compression Ratio ) using a
variable-compression engine. His numbers were not absolute, as there were
many variables, such as ignition timing, cleanliness, spark plug position,
engine temperature. etc.
In 1927 Graham Edgar suggested using two hydrocarbons that could be produced
in sufficient purity and quantity [11]. These were "normal heptane", that
was already obtainable in sufficient purity from the distillation of Jeffrey
pine oil, and " an octane, named 2,4,4-trimethyl pentane " that he first
synthesized. Today we call it " iso-octane " or 2,2,4-trimethyl pentane. The
octane had a high antiknock value, and he suggested using the ratio of the
two as a reference fuel number. He demonstrated that all the commercially-
available gasolines could be bracketed between 60:40 and 40:60 parts by
volume heptane:iso-octane.
The reason for using normal heptane and iso-octane was because they both
have similar volatility properties, specifically boiling point, thus the
varying ratios 0:100 to 100:0 should not exhibit large differences in
volatility that could affect the rating test.
Heat of
Melting Point Boiling Point Density Vaporisation
C C g/ml MJ/kg
normal heptane -90.7 98.4 0.684 0.365 @ 25C
iso octane -107.45 99.3 0.6919 0.308 @ 25C
Having decided on standard reference fuels, a whole range of engines and
test conditions appeared, but today the most common are the Research Octane
Number ( RON ), and the Motor Octane Number ( MON ).
6.2 Why do we need Octane Ratings?
To obtain the maximum energy from the gasoline, the compressed fuel-air
mixture inside the combustion chamber needs to burn evenly, propagating out
from the spark plug until all the fuel is consumed. This would deliver an
optimum power stroke. In real life, a series of pre-flame reactions will
occur in the unburnt "end gases" in the combustion chamber before the flame
front arrives. If these reactions form molecules or species that can
autoignite before the flame front arrives, knock will occur [21,22].
Simply put, the octane rating of the fuel reflects the ability of the
unburnt end gases to resist spontaneous autoignition under the engine test
conditions used. If autoignition occurs, it results in an extremely rapid
pressure rise, as both the desired spark-initiated flame front, and the
undesired autoignited end gas flames are expanding. The combined pressure
peak arrives slightly ahead of the normal operating pressure peak, leading
to a loss of power and eventual overheating. The end gas pressure waves are
superimposed on the main pressure wave, leading to a sawtooth pattern of
pressure oscillations that create the "knocking" sound.
The combination of intense pressure waves and overheating can induce piston
failure in a few minutes. Knock and preignition are both favoured by high
temperatures, so one may lead to the other. Under high-speed conditions
knock can lead to preignition, which then accelerates engine destruction
[27,28].
6.3 What fuel property does the Octane Rating measure?
The fuel property the octane ratings measure is the ability of the unburnt
end gases to spontaneously ignite under the specified test conditions.
Within the chemical structure of the fuel is the ability to withstand
pre-flame conditions without decomposing into species that will autoignite
before the flame-front arrives. Different reaction mechanisms, occurring at
various stages of the pre-flame compression stroke, are responsible for the
undesirable, easily-autoignitable, end gases.
During the oxidation of a hydrocarbon fuel, the hydrogen atoms are removed
one at a time from the molecule by reactions with small radical species
(such as OH and HO2), and O and H atoms. The strength of carbon-hydrogen
bonds depends on what the carbon is connected to. Straight chain HCs such as
normal heptane have secondary C-H bonds that are significantly weaker than
the primary C-H bonds present in branched chain HCs like iso-octane [21,22].
The octane rating of hydrocarbons is determined by the structure of the
molecule, with long, straight hydrocarbon chains producing large amounts of
easily-autoignitable pre-flame decomposition species, while branched and
aromatic hydrocarbons are more resistant. This also explains why the octane
ratings of paraffins consistently decrease with carbon number. In real life,
the unburnt "end gases" ahead of the flame front encounter temperatures up
to about 700C due to compression and radiant and conductive heating, and
commence a series of pre-flame reactions. These reactions occur at different
thermal stages, with the initial stage ( below 400C ) commencing with the
addition of molecular oxygen to alkyl radicals, followed by the internal
transfer of hydrogen atoms within the new radical to form an unsaturated,
oxygen-containing species. These new species are susceptible to chain
branching involving the HO2 radical during the intermediate temperature
stage (400-600C), mainly through the production of OH radicals. Above 600C,
the most important reaction that produces chain branching is the reaction of
one hydrogen atom radical with molecular oxygen to form O and OH radicals.
The addition of additives such as alkyl lead and oxygenates can
significantly affect the pre-flame reaction pathways. Antiknock additives
work by interfering at different points in the pre-flame reactions, with
the oxygenates retarding undesirable low temperature reactions, and the
alkyl lead compounds react in the intermediate temperature region to
deactivate the major undesirable chain branching sequence [21,22].
The antiknock ability is related to the "autoignition temperature" of the
hydrocarbons. Antiknock ability is _not_ substantially related to:-
1. The energy content of fuel, this should be obvious, as oxygenates have
lower energy contents, but high octanes.
2. The flame speed of the conventionally ignited mixture, this should be
evident from the similarities of the two reference hydrocarbons.
Although flame speed does play a minor part, there are many other factors
that are far more important. ( such as compression ratio, stoichiometry,
combustion chamber shape, chemical structure of the fuel, presence of
antiknock additives, number and position of spark plugs, turbulence etc.)
Flame speed does not correlate with octane.
6.4 Why are two ratings used to obtain the pump rating?
The correct name for the (RON+MON)/2 formula is the "antiknock index",
and it remains the most important quality criteria for motorists [39].
The initial knock measurement methods developed in the 1920s resulted in a
diverse range of engine test methods and conditions, many of which have been
summarised by Campbell and Boyd [103]. In 1928 the Co-operative Fuel Research
Committee formed a sub-committee to develop a uniform knock-testing
apparatus and procedure. They settled on a single-cylinder, valve-in-head,
water-cooled, variable compression engine of 3.5"bore and 4.5" stroke. The
knock indicator was the bouncing-pin type. They selected operating conditions
for evaluation that most closely match the current Research Method, however
correlation trials with road octanes in the early 1930s exhibited such large
discrepancies that conditions were changed ( higher engine speed, hot mixture
temperature, and defined spark advance profiles ), and a new tentative ASTM
Octane rating method was produced. This method is similar to the operating
conditions of the current Motor Octane procedure [12,103]. Over several
decades, a large number of alternative octane test methods appeared. These
were variations to either the engine design, or the specified operating
conditions [103]. During the 1950-1960s attempts were made to internationally
standardise and reduce the number of Octane Rating test procedures.
During the late 1940s - mid 1960s, the Research method became the important
rating because it more closely represented the octane requirements of the
motorist using the fuels/vehicles/roads then available. In the late 1960s
German automakers discovered their engines were destroying themselves on
long Autobahn runs, even though the Research Octane was within specification.
They discovered that either the MON or the Sensitivity ( the numerical
difference between the RON and MON numbers ) also had to be specified. Today
it is accepted that no one octane rating covers all use. In fact, during
1994, there have been increasing concerns in Europe about the high
Sensitivity of some commercially-available unleaded fuels.
The design of the engine and vehicle significantly affect the fuel octane
requirement for both RON and MON. In the 1930s, most vehicles would have
been sensitive to the Research Octane of the fuel, almost regardless of the
Motor Octane, whereas most 1990s engines have a 'severity" of one, which
means the engine is unlikely to knock if a changes of one RON is matched by
an equal and opposite change of MON [32]. I should note that the Research
method was only formally approved in 1947, but used unofficially from 1942.
6.5 What does the Motor Octane rating measure?
The conditions of the Motor method represent severe, sustained high speed,
high load driving. For most hydrocarbon fuels, including those with either
lead or oxygenates, the motor octane number (MON) will be lower than the
research octane number (RON).
Test Engine conditions Motor Octane
Test Method ASTM D2700-92 [104]
Engine Cooperative Fuels Research ( CFR )
Engine RPM 900 RPM
Intake air temperature 38 C
Intake air humidity 3.56 - 7.12 g H2O / kg dry air
Intake mixture temperature 149 C
Coolant temperature 100 C
Oil Temperature 57 C
Ignition Advance - variable Varies with compression ratio
( eg 14 - 26 degrees BTDC )
Carburettor Venturi 14.3 mm
6.6 What does the Research Octane rating measure?
The Research method settings represent typical mild driving, without
consistent heavy loads on the engine.
Test Engine conditions Research Octane
Test Method ASTM D2699-92 [105]
Engine RPM 600 RPM
Intake air temperature Varies with barometric pressure
( eg 88kPa = 19.4C, 101.6kPa = 52.2C )
Intake mixture temperature Not specified
Ignition Advance - fixed 13 degrees BTDC
Carburettor Venturi Set according to engine altitude
( eg 0-500m=14.3mm, 500-1000m=15.1mm )
6.7 Why is the difference called "sensitivity"?
RON - MON = Sensitivity. Because the two test methods use different test
conditions, especially the intake mixture temperatures and engine speeds,
then a fuel that is sensitive to changes in operating conditions will have
a larger difference between the two rating methods. Modern fuels typically
have sensitivities around 10. The US 87 (RON+MON)/2 unleaded gasoline is
recommended to have a 82+ MON, thus preventing very high sensitivity fuels
[39]. Recent changes in European gasolines has caused concern, as high
sensitivity unleaded fuels have been found that fail to meet the 85 MON
requirement of the EN228 European gasoline specification [106].
6.8 What sort of engine is used to rate fuels?
Automotive octane ratings are determined in a special single-cylinder engine
with a variable compression ratio ( CR 4:1 to 18:1 ) known as a Cooperative
Fuels Research ( CFR ) engine. The cylinder bore is 82.5mm, the stroke is
114.3mm, giving a displacement of 612 cm3. The piston has four compression
rings, and one oil control ring. The intake valve is shrouded. The head and
cylinder are one piece, and can be moved up and down to obtain the desired
compression ratio. The engines have a special four-bowl carburettor that
can adjust individual bowl air-fuel ratios. This facilitates rapid switching
between reference fuels and samples. A magnetorestrictive detonation sensor
in the combustion chamber measures the rapid changes in combustion chamber
pressure caused by knock, and the amplified signal is measured on a
"knockmeter" with a 0-100 scale [104,105]. A complete Octane Rating engine
system costs about $200,000 with all the services installed. Only one
company manufactures these engines, the Waukesha Engine Division of Dresser
Industries, Waukesha. WI 53186.
6.9 How is the Octane rating determined?
To rate a fuel, the engine is set to an appropriate compression ratio that
will produce a knock of about 50 on the knockmeter for the sample when the
air-fuel ratio is adjusted on the carburettor bowl to obtain maximum knock.
Normal heptane and iso-octane are known as primary reference fuels. Two
blends of these are made, one that is one octane number above the expected
rating, and another that is one octane number below the expected rating.
These are placed in different bowls, and are also rated with each air-fuel
ratio being adjusted for maximum knock. The higher octane reference fuel
should produce a reading around 30-40, and the lower reference fuel should
produce a reading of 60-70. The sample is again tested, and if it does not
fit between the reference fuels, further reference fuels are prepared, and
the engine readjusted to obtain the required knock. The actual fuel rating
is interpolated from the knockmeter readings [104,105].
6.10 What is the Octane Distribution of the fuel?
The combination of vehicle and engine can result in specific requirements
for octane that depend on the fuel. If the octane is distributed differently
throughout the boiling range of a fuel, then engines can knock on one brand
of 87 (RON+MON)/2, but not on another brand. This "octane distribution" is
especially important when sudden changes in load occur, such as high load,
full throttle, acceleration. The fuel can segregate in the manifold, with
the very volatile fraction reaching the combustion chamber first and, if
that fraction is deficient in octane, then knock will occur until the less
volatile, higher octane fractions arrive [27,28].
Some fuel specifications include delta RONs, to ensure octane distribution
throughout the fuel boiling range was consistent. Octane distribution was
seldom a problem with the alkyl lead compounds, as the tetra methyl lead
and tetra ethyl lead octane volatility profiles were well characterised, but
it can be a major problem for the new, reformulated, low aromatic gasolines,
as MTBE boils at 55C, whereas ethanol boils at 78C. Drivers have discovered
that an 87 (RON+MON)/2 from one brand has to be substituted with an 89
(RON+MON)/2 of another, and that is because of the combination of their
driving style, engine design, vehicle mass, fuel octane distribution, fuel
volatility, and the octane-enhancers used.
6.11 What is a "delta Research Octane number"?
To obtain an indication of behaviour of a gasoline during any manifold
segregation, an octane rating procedure called the Distribution Octane
Number was used. The rating engine had a special manifold that allowed
the heavier fractions to be separated before they reached the combustion
chamber [27]. That method has been replaced by the "delta" RON procedure.
The fuel is carefully distilled to obtain a distillate fraction that boils
to the specified temperature, which is usually 100C. Both the parent fuel
and the distillate fraction are rated on the octane engine using the
Research Octane method [107]. The difference between these is the delta
RON(100C), usually just called the delta RON. The delta RON ratings are
not particularly relevant to engines with injectors, and are not used in
the US.
6.12 How do other fuel properties affect octane?
Several other properties affect knock. The most significant determinant of
octane is the chemical structure of the hydrocarbons and their response to
the addition of octane enhancing additives. Other factors include:-
Front End Volatility - Paraffins are the major component in gasoline, and
the octane number decreases with increasing chain length or ring size, but
increases with chain branching. Overall, the effect is a significant
reduction in octane if front end volatility is lost, as can happen with
improper or long term storage. Fuel economy on short trips can be improved
by using a more volatile fuel, at the risk of carburettor icing and
increased evaporative emissions.
Final Boiling Point.- Decreases in the final boiling point increase fuel
octane. Aviation gasolines have much lower final boiling points than
automotive gasolines. Note that final boiling points are being reduced
because the higher boiling fractions are responsible for disproportionate
quantities of pollutants and toxins.
Preignition tendency - both knock and preignition can induce each other.
6.13 Can higher octane fuels give me more power?
On modern engines with sophisticated engine management systems, the engine
can operate efficiently on fuels of a wider range of octane rating, but there
remains an optimum octane for the engine under specific driving conditions.
Older cars without such systems are more restricted in their choice of fuel,
as the engine can not automatically adjust to accommodate lower octane fuel.
Because knock is so destructive, owners of older cars must use fuel that will
not knock under the most demanding conditions they encounter, and must
continue to use that fuel, even if they only occasionally require the octane.
If you are already using the proper octane fuel, you will not obtain more
power from higher octane fuels. The engine will be already operating at
optimum settings, and a higher octane should have no effect on the management
system. Your driveability and fuel economy will remain the same. The higher
octane fuel costs more, so you are just throwing money away. If you are
already using a fuel with an octane rating slightly below the optimum, then
using a higher octane fuel will cause the engine management system to move to
the optimum settings, possibly resulting in both increased power and improved
fuel economy. You may be able to change octanes between seasons ( reduce
octane in winter ) to obtain the most cost-effective fuel without loss of
driveability.
Once you have identified the fuel that keeps the engine at optimum settings,
there is no advantage in moving to an even higher octane fuel. The
manufacturer's recommendation is conservative, so you may be able to
carefully reduce the fuel octane. The penalty for getting it badly wrong,
and not realising that you have, could be expensive engine damage.
6.14 Does low octane fuel increase engine wear?
Not if you are meeting the octane requirement of the engine. If you are not
meeting the octane requirement, the engine will rapidly suffer major damage
due to knock. You must not use fuels that produce sustained audible knock,
as engine damage will occur. If the octane is just sufficient, the engine
management system will move settings to a less optimal position, and the
only major penalty will be increased costs due to poor fuel economy.
Whenever possible, engines should be operated at the optimum position for
long-term reliability. Engine wear is mainly related to design,
manufacturing, maintenance and lubrication factors. Once the octane and
run-on requirements of the engine are satisfied, increased octane will have
no beneficial effect on the engine. Run-on is the tendency of an engine to
continue running after the ignition has been switched off, and is discussed
in more detail in Section 8.2. The quality of gasoline, and the additive
package used, would be more likely to affect the rate of engine wear, rather
than the octane rating.
6.15 Can I mix different octane fuel grades?
Yes, however attempts to blend in your fuel tank should be carefully
planned. You should not allow the tank to become empty, and then add 50% of
lower octane, followed by 50% of higher octane. The fuels may not completely
mix immediately, especially if there is a density difference. You may get a
slug of low octane that causes severe knock. You should refill when your
tank is half full. In general the octane response will be linear for most
hydrocarbon and oxygenated fuels eg 50:50 of 87 and 91 will give 89.
Attempts to mix leaded high octane to unleaded high octane to obtain higher
octane are useless for most commercial gasolines. The lead response of the
unleaded fuel does not overcome the dilution effect, thus 50:50 of 96 leaded
and 91 unleaded will give 94. Some blends of oxygenated fuels with ordinary
gasoline can result in undesirable increases in volatility due to volatile
azeotropes, and some oxygenates can have negative lead responses. The octane
requirement of some engines is determined by the need to avoid run-on, not
to avoid knock.
6.16 What happens if I use the wrong octane fuel?
If you use a fuel with an octane rating below the requirement of the engine,
the management system may move the engine settings into an area of less
efficient combustion, resulting in reduced power and reduced fuel economy.
You will be losing both money and driveability. If you use a fuel with an
octane rating higher than what the engine can use, you are just wasting
money by paying for octane that you can not utilise. The additive packages
are matched to the engines using the fuel, for example intake valve deposit
control additive concentrations may be increased in the premium octane grade.
If your vehicle does not have a knock sensor, then using a fuel with an
octane rating significantly below the octane requirement of the engine means
that the little men with hammers will gleefully pummel your engine to pieces.
You should initially be guided by the vehicle manufacturer's recommendations,
however you can experiment, as the variations in vehicle tolerances can
mean that Octane Number Requirement for a given vehicle model can range
over 6 Octane Numbers. Caution should be used, and remember to compensate
if the conditions change, such as carrying more people or driving in
different ambient conditions. You can often reduce the octane of the fuel
you use in winter because the temperature decrease and possible humidity
changes may significantly reduce the octane requirement of the engine.
Use the octane that provides cost-effective driveability and performance,
using anything more is waste of money, and anything less could result in
an unscheduled, expensive visit to your mechanic.
6.17 Can I tune the engine to use another octane fuel?
In general, modern engine management systems will compensate for fuel octane,
and once you have satisfied the optimum octane requirement, you are at the
optimum overall performance area of the engine map. Tuning changes to obtain
more power will probably adversely affect both fuel economy and emissions.
Unless you have access to good diagnostic equipment that can ensure
regulatory limits are complied with, it is likely that adjustments may be
regarded as illegal tampering by your local regulation enforcers. If you are
skilled, you will be able to legally wring slightly more performance from
your engine by using a dynamometer in conjunction with engine and exhaust gas
analyzers and a well-designed, retrofitted, performance engine management
chip.
6.18 How can I increase the fuel octane?
Not simply, you can purchase additives, however these are not cost-effective
and a survey in 1989 showed the cost of increasing the octane rating of one
US gallon by one unit ranged from 10 cents ( methanol ), 50 cents (MMT),
$1.00 ( TEL ), to $3.25 ( xylenes ) [108]. Refer to section 6.20 for a
discussion on naphthalene ( mothballs ). It is preferable to purchase a
higher octane fuel such as racing fuel, aviation gasolines, or methanol.
Sadly, the price of chemical grade methanol has almost doubled during 1994.
If you plan to use alcohol blends, ensure your fuel handling system is
compatible, and that you only use dry gasoline by filling up early in the
morning when the storage tanks are cool. Also ensure that the service station
storage tank has not been refilled recently. Retailers are supposed to wait
several hours before bringing a refilled tank online, to allow suspended
undissolved water to settle out, but they do not always wait the full period.
6.19 Are aviation gasoline octane numbers comparable?
Aviation gasolines were all highly leaded and graded using two numbers, with
common grades being 80/87, 100/130, and 115/145 [109,110]. The first number is
the Aviation rating ( aka Lean Mixture rating ), and the second number is the
Supercharge rating ( aka Rich Mixture rating ). In the 1970s a new grade,
100LL ( low lead = 0.53mlTEL/L instead of 1.06mlTEL/L) was introduced to
replace the 80/87 and 100/130. Soon after the introduction, there was a
spate of plug fouling, and high cylinder head temperatures resulting in
cracked cylinder heads [110]. The old 80/87 grade was reintroduced on a
limited scale. The Aviation Rating is determined using the automotive Motor
Octane test procedure, and then converted to an Aviation Number using a
table in the method. Aviation Numbers below 100 are Octane numbers, while
numbers above 100 are Performance numbers. There is usually only 1 - 2
Octane units different to the Motor value up to 100, but Performance numbers
varies significantly above that eg 110 MON = 128 Performance number.
The second Avgas number is the Rich Mixture method Performance Number ( PN
- they are not commonly called octane numbers when they are above 100 ), and
is determined on a supercharged version of the CFR engine which has a fixed
compression ratio. The method determines the dependence of the highest
permissible power ( in terms of indicated mean effective pressure ) on
mixture strength and boost for a specific light knocking setting. The
Performance Number indicates the maximum knock-free power obtainable from a
fuel compared to iso-octane = 100. Thus, a PN = 150 indicates that an engine
designed to utilise the fuel can obtain 150% of the knock-limited power of
iso-octane at the same mixture ratio. This is an arbitrary scale based on
iso-octane + varying amounts of TEL, derived from a survey of engines
performed decades ago. Aviation gasoline PNs are rated using variations of
mixture strength to obtain the maximum knock-limited power in a supercharged
engine. This can be extended to provide mixture response curves which define
the maximum boost ( rich - about 11:1 stoichiometry ) and minimum boost
( weak about 16:1 stoichiometry ) before knock [110].
The 115/145 grade is being phased out, but even the 100LL has more octane
than any automotive gasoline.
6.20 Can mothballs increase octane?
The legend of mothballs as an octane enhancer arose well before WWII when
naphthalene was used as the active ingredient. Today, the majority of
mothballs use para-dichlorobenzene in place of naphthalene, so choose
carefully if you wish to experiment . There have been some concerns about
the toxicity of para-dichlorobenzene, and naphthalene mothballs have again
become popular. In the 1920s, typical gasoline octane ratings were 40-60
[11], and during the 1930s and 40s, the ratings increased by approximately 20
units as alkyl leads and improved refining processes became widespread [12].
Naphthalene has a blending motor octane number of 90 [52], so the addition of
a significant amount of mothballs could increase the octane, and they were
soluble in gasoline. The amount usually required to appreciably increase the
octane also had some adverse effects. The most obvious was due to the high
melting point ( 80C ), when the fuel evaporated the naphthalene would
precipitate out, blocking jets and filters. With modern gasolines,
naphthalene is more likely to reduce the octane rating, and the amount
required for low octane fuels will also create operational and emissions
problems.
Old Jun 13, 2005 | 04:49 PM
Stan's Avatar
Where is my Turbo?
http://auto.howstuffworks.com/question90.htm
Old Jun 13, 2005 | 05:03 PM
osama tim laden's Avatar
kings cannot fall.
cliffs notes:
one of them is higher octane than the other.
and one of them is in the middle. its usually refered to as "mid grade"
Old Jun 13, 2005 | 05:10 PM
Rdline1's Avatar
Hi Hi Hi?
Heat of
C C g/ml MJ/kg
[27,28].
Engine RPM 900 RPM
Engine RPM 600 RPM
the US.
driveability.
to avoid knock.
chip.
problems.
what he said
98 Camry w00t! (daily ride)
91' Eclipse GS-t (she's alive!!)
AOL IM: usfbull49
Originally Posted by Frankie
When a jelly fish comes out of my ass, I'll take pics.
Old Jun 13, 2005 | 05:22 PM
Young,Fablous,&Broke's Avatar
longest post evar!
Old Jun 13, 2005 | 05:30 PM
myltwon's Avatar
Bolt-On 2v GT
cliff notes: higher octane = better effciency & less knock
I had some lady at my job tell me her car wouldn't run on anything except regular and I was an idiot for thinking otherwise
Old Jun 13, 2005 | 05:33 PM
can survive...
the higher octain is a waste of money if your car doesnt need it.
Old Jun 13, 2005 | 05:37 PM
myltwon's Avatar
Bolt-On 2v GT
yes it is but that lady told me her car WILL NOT run if there is 93 octane in it
noname's Avatar
Venezolano...!
Heat of
C C g/ml MJ/kg
[27,28].
Engine RPM 900 RPM
Engine RPM 600 RPM
the US.
driveability.
to avoid knock.
chip.
problems.
What would have made it crazy is if you actually typed all this
