what to use on a ITR motor.
on
i was wondering if anyone had any suggestions on what type of turbo kit to put on a type r motor with 9.1:1 thanks.
jason.
jason.
:FASQUAD:
:FASQUAD:
Why would you turbo an ITR engine!? Why not buy a GSR engine to turbo? It's the same block, CHEAPER, and you don't have to rip it apart and build it when you first get it, it's already decent for turbo.
There's no point in buying an ITR to turbo it, you're ripping it apart and changing what makes it great to begin with.
Guest
Posts: n/a
m4yb3 7h3 3|\|g1|\|3 4l|234dy h45 9:1 C|2 f|20m 4 p|23v10u5 0\^/|\|3|2? 1'd 7u|2b0 17 4|\|y\^/4y, 533 51g. 7u|2b0 17|2'5 4|23 4 bl457!
\^/h47 7u|2b0 k17 y0u \^/0uld \^/4|\|7 15 g01|\|g 70 g|2347ly d3p3|\|d 0|\| h0\^/ much p0\^/3|2 y0u \^/4|\|7 0u7 0f 17. F0|27u|\|473ly f0|2 y0u, 7h3|23 4|23 0p710|\|5 4v41l4bl3 70 5u17 g04l5 f|20m 250\^/hp 70 45 much 45 y0u c0uld 3v3|2 p0551bly \^/4|\|7.
on
:FASQUAD:
:FASQUAD:
Either do it custom, or Full Race makes some nice kits that put down alot of power. THat block should be able to handle a shitload of boost...
Obsession is a word used by the lazy to describe the dedicated.
GO GATORS
GO GATORS
Is it sleeved ?
I say Full-Race Stage 3 or a custom setup .... Depends on your power goals etc ...
Hondata saves lives
Hondata saves lives
Just saw the 2l part ..
Definately Full-Race then ... Add a fuel system and Neptune and go run some nice times ...
Hondata saves lives
Hondata saves lives
check the code stamping on the head and look for the green mark. I forget where it is but all ITR heads have it.
Racing Integration
LHT Performance
My tuner is named Alpha
Racing Integration
LHT Performance
