Who thinks they understand the difference between Tq and horsepower....
Originally Posted by Ostrich
Al,
Actually Dynojet is correct.
All they are is measuring horsepower.
Horsepower as a unit of how much work was done. They know how much it weighs, they know how long it took to spin it up to the speed that they know, and from there they can calculate the amount of work (horsepower) done, and where it was done.
This is why you need an RPM reading on an engine to get a correct torque reading.
how the actual force being applied to the roller is torque, but the roller is not measuring the instantaneous rate of change and the torque being applied to it. It only has to measure the amount of time it takes to spin the known mass up, and with that it calculates horsepower.
Exactly....but you cant make a drum that large and fill it with concrete or whatever is in it to extremely close tolerance so that one calibration fits every drum. I am suspecting they have something back at the factory that applies a known Tq to the drum to calibrate each drum. My point is you cant DIRECTLY measure HP like you can TQ. Even the dynojets HP measurement is a calculation of HP based on time and acceleration which in turn was calibrated back at the facory with DIRECT MEASUREMENT of tq applied to that specific drum.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Guest
Posts: n/a
Exactly, it calculates the horsepower. It isn't something that can be measured on it's own.
I can see your point about the Dynojet not measuring actual torque because they know the variables in play and they already know how much torque it will take to spin the roller x amount of times in y seconds. But they are still using torque and RPM to determine the horsepower of the car on the dyno.
It's not really worth arguing over since it's all symantics in regards to how Dynojet wants to advertise their product.
Originally Posted by HybridSS
Depends on wether its a dynojet or something like a mustang dyno. Mustang dynos and Land & Sea dynoes have some type of load cell that does DIRECTLY MEASURE TQ. Then it uses the rpm pickup to calculate the HP figure.
Dynojet claims on thier website that they are measuring HP. But this isnt really true. All they have done is calculated a standard back at the factory based on the weight and diameter of thier drum. They probably have some type of system that applies a known TQ to each drum to accelerate it and then they can calculate the software calibration for that system.
You can't just measure the torque at the wheels and use the engine RPM for the calculation. The numbers would change dramatically with gear ratio differences, and they don't. What is really measured is horsepower at the rear wheels and that then is translated into engine torque via the normal calculation based on engine rpm.
Here is a great explanation that I found (I would claim it as my own, but everyone here knows I ain't no damn mathmagician!):
"A combination of two laws of physics, force equals mass times acceleration and work equals force times distance, gives us this equation: W=m X a X d. "W" is the work, in pounds-feet, the rear wheels are doing, "m" is mass equivalent (the drums), "a" is acceleration (increasing drive wheel speed) and "d" is distance (drum circumference). Once we have the work, we can find horsepower. One horsepower is 550 pounds-feet of work done in one second so, we divide the work number by the length of time measured, then divide the number we get from that by 550. To simplify: we get horsepower by multiplying the mass, acceleration and the distance, then dividing that product by time multiplied by 550. This can be expressed by: hp = (m X a X d) ÷ (t X 550).
Torque can be figured by multiplying the horsepower by a constant, 5252, then dividing that product by the speed at which the thrust force was measured. Generally, with rear wheel numbers, axle ratio is not considered in the torque computation. For comparison purposes, this makes more sense. The computer factors out the axle ratio by using engine speed data in the torque derivation."
I know that is sorta hard to follow but if you really think about what is saying you can see that rear wheel horsepower is measured before engine horepower OR torque is calculated...thus eliminating the gear ratio factor.
The key point im trying to make is DIRECTLY MEASURE. there is no machine anywhere that I know of that can directly measure HP. Everything used to determine HP will be a calculation of atleast two parameters being directly measured. Wether those two parameters are time and mass or TQ and rpm. There will always be two. Tq on the other hand...is just measured straight up right from the source...DIRECTLY.
That pretty much sums it up
Dynojet won the advertising and sales pitch wars big time. Dont get me wrong though...I like the dynojet.
Guest
Posts: n/a
the dynojet measures HP indirectly as its primary goal.
it determines HP based on the change in angular velocity of a known mass of a steel drum. in theory the dynoject measures nothing. it calculates time based on a processor operation. then it calculates the amount of time between speed sensor puleses off the axle. it then knows (by programmed value) what sensor pulse rate equals what angular velocity. using a known mass and moment of inertia of the steel drum assembly the computer is able apply theses values to a formula. if the cpu can determine how much the angular velocity of a known mass has changed over a given period of time it can then determine how much work is being done to the mass and thus how much power is being delivered.
so...
there is nothing in a dynojet that MEASUERES tq. the tq is calculated by taking the calculated HP and dividing it by an RPM value that the sensor box acquires off the vehicle.
if you make a pull on the dynojet and dont hook up any sensors to the vehicle you will get a graph of HP vs. wheel speed! so no TQ is measured.
whoever stated that all dynos measure TQ is wrong ...and i know the british website that you got that quote off of...and he is wrogn in that statement.
the Dynojet does not measure TQ or HP. it measures time..and then calculates HP.
so...
I'm pretty comfortable with this. It makes perfect sense to measure the changes in velocity over time of a known amount of mass to calculate HP. And its probably much easier than applying a constant resistive force, such as a brake or an electric motor functioning as a brake (generator mode).
I was under the impression that the mass type dyno's mask rapid fluctuations in the HP/TQ curves. I can't remember the exact name, but in the threads where a guy has the 'ultimate garage', he had a dyno system that attached directly to the hubs.
"They must really feed each other to the lions down there........"
my question is, if f = m x a (which obviously it does), what force f is being measured? torque? torque divided by the wheel's radius, as mentioned above? and is that an oversimplification? obviously it's negating outside factors like wind resistance, etc. but as far as the actual mechanics involved, what is the force which, when divided by the mass of the vehicle (or would it be the mass of the engine?), gives you your acceleration?
and did any of that even make sense?
you are correct.
the driving "force" accelerating the vehicle (which i shall call thrust) is the force the road exerts on the tires (which is equal in magnitude and opposite in direction to the force the tires exert on the road--newton's third law thing).
basically as the wheel turns (via torque from the axle), it exerts a force on the road tangental to the surface of the tire (that is, perpendicular to the RADIUS of the wheel). the torque the axle delivers is determined by the torque the engine produces, multiplied by the mechanical advantage of the gearing, and subtracting any frictional losses through the drivetrain.
the car is accelerated by the force the road exerts on the tire, and this is equivalent to the torque the tire exerts on the road (again, by newton's 3rd law), divided by the radius of the tire (which is equivalent to the force vector portion of the torque).
Shawn
The answer to your question is sqrt(pi)
Shawn
