Question about engine thermodynamics
Flipping through the new (March 2005) issue of C/D came upon an article about mpg/engine efficiency. In the article it states that if heat is retained with an "interheater" (opposite of intercooler) in the engine is actually more efficient, even though it's detrimental to the cylinder head.
(that's an understatement)
I always thought that the cooler an engine stays, the more efficient it is and thus produces more power. WTF?
Is anyone well educated in this field?
Please put in your $0.02
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
If not for detonation and material issues, an engine that could run at 1800 degrees would be more efficient than an engine that runs at 250 degrees.
The easiest way to look at it is that the hotter engine will cool the burning air and fuel less, resulting in that heat expanding the gas instead and creating more power.
Some turbine engines use preheaters to heat the compressed air before igniting it so that the fuel energy is put to additional work by adding energy to the new mix.
From what i've read (something about aluminum heads vs cast heads a looooong time ago...), a hotter combustion chamber will burn fuel more efficiently...
That is what i read.
[QUOTE=0HP930]If not for detonation and material issues, an engine that could run at 1800 degrees would be more efficient than an engine that runs at 250 degrees.
[QUOTE]
I think that's the point they were trying to get across- that in theory the hotter it runs the more efficientit will become.
[QUOTE]
