Gear Install
Old Feb 1, 2005 | 01:22 PM
myltwon's Avatar
Bolt-On 2v GT
Default Gear Install
anyone know how much a shop usually charges for a gear install on a 10 bolt?
Old Feb 1, 2005 | 07:43 PM
myltwon's Avatar
Bolt-On 2v GT
TTT
Old Feb 2, 2005 | 06:57 AM
F*r*a*n*k*e*i's Avatar
$400-$500. It's usually $200 for the set of gears + $250-$300 in labor. That shit has to be setup with pretty precise detail, so they just bend you over the counter for labor costs.
Old Feb 2, 2005 | 06:58 AM
Oh, I'm assuming you wanted this done on your 7.5" rearend right? You're probably better off just buying a new rearend all together with a larger ring gear if you're going to bother.
Old Feb 2, 2005 | 06:59 AM
myltwon's Avatar
Bolt-On 2v GT
yeah from alot of the installs I've been looking at it isn't a big job, just requires tons of precision measurements
Old Feb 2, 2005 | 07:03 AM
Exactly. If it's not setup right it'll whine and prematurely wear the gear. Worst case scenario, the rear end grenades under heavy load, you trow a ride and bollocks up your transmission in the process.
Is this an automatic LT1 you're swapping the rear gear on or a 6 speed manual?
Old Feb 2, 2005 | 08:10 AM
myltwon's Avatar
Bolt-On 2v GT
auto planning on going from a 3.23 to a 3.73
I hear moser's are noisey so I'm gonna try motive or strange
Old Feb 2, 2005 | 08:17 AM
HerHotRod's Avatar
The Happy Mrs.
Try Allens Gearworks, 727-784-0452. He on the side street next to the Home Depot at Curlew and 19.
He did my 12 bolt over 5 yrs. ago and never had a problem or whining gears. I brought him the posi, which he rebuilt, bought the gears from him, had him put in longer wheel studs, brngs, etc. and assemble it all together. I did bring it to him out of the car and I put in the car myself when he was done. I think I spent around $600, yrs back.
Call him for a quote, he's good.
Old Feb 2, 2005 | 01:27 PM
3.73 on a 4 speed sucks, trust me, I know. You might want to consider picking up a scrapped 3.40-whatever stock read end from a manual 6 speed car. You can get them for about $150 and drop it in yourself. It'll save you a lot of cash.
I thought the A4 LT1's had 2.73 in the back stock, not 3.23.
Old Feb 2, 2005 | 06:33 PM
myltwon's Avatar
Bolt-On 2v GT
3.23s were an option, most had 2.73s
the 1994 trans am gt had 2-3 things that made it different than a trans am
raised spoiler and 3.23s in the auto 3.43s in the manual
p.s. - how will changing from a 3.23 to a 3.43 be easier than going from a 3.23 to a 3.73?
they are all 3 series carrier gears, if you want to share you knowledge and help with the install that'd be nice
