how much hp would this make?
i was at a car show last night at burgerking in citrus park and there was a supra there with a t-88 running 46 lbs with a 5inch exhaust. it was sick. how much would you guys think this thing would lay down to the wheels?
what color was it ?
On a more serious note..
Someone with a greddy t88 made 542 rwhp at 18 psi and 815 rwhp at 34 psi...You could probably figure out what it'd make (ballpark figure) at 43 psi with that info.
If it was a turbonetics on the other hand...
T88: at high boost pressures it requires a *much* larger flow of air than the 2JZ can support to avoid surge according to calculations. Of course this isn't a problem if the turbo doesn't spool until 8k rpms.
i know the car, you guys are thinking of the Greddy T88, and rightfully so, however, he is using a true GT47, 88mm (hence, T8
, on 46psi, the car put down 1147 rwhp...its fast
Poppa J. Smurf
Poppa J. Smurf
ya he told me it didnt spool till about 5.5k
