blue headlight bulbs
Originally posted by REY78
Nokya are the STREET LEGAL blue bulbs that give you the best blue-ish appearance - but caution, they don't last long.
HID is the ONLY TRUE conversion for that BMW, high end look
I bought my Nokyas at Racingzone in orlando, and my PIAAs at sound advice for whoever was asking.
go on ebay and look up nokya. they are bright and have a nice tint like everyone is saying. someone said they dont last long, ive had them on 2 of my cars and never had a problem
Gripped XS | 18-55 IS | 50mm f/1.8 MK II | Sunpak 5000af
to do a hid conversion, the most accurate way is to retrofit highend car projectors into your factory projectors or aftermarket projectors
parts for an hid conversion includes
hid ballast x2
hid ignitor x2 some ballast might have this built in
hid bulbs x2 - 4100k for yellower look 4500k for factory white and 6000k for ultrons anything over 6000k, the hid becomes inefficent, since most human eyes cannot see most of the llight after 6k
hid projectors x2 - some people use h7 projectors because it produce a similar beam pattern, one of the most popular projector is the s2000 projector because its small and compact, which lead to it's ability to be fitted into most projectors, i personally have valeo h7 with hid base plates. becareful on choosing an h7 projectors too, not all of them will get the results you want
a few misconceptions:
the blue and purple on most cars are not the color of the bulb, the bulb infact release white light, and the projector's cut off portion spreads the light like a prizm, which gives that multicolor effect while going over speed bumps
those blue bulbs are nothing other than regular halogen with a blue film over it, which filters out the yellow in the bulb, the disadvantage of that is less usable light will be on the groud, making the ground dimmer, try to see next time you are on a wet road, notice it's much more difficult. some manufactures of "fake hid" raise the voltage on the bulb to produce more light, which release more heat and often melt wires around it
hid actually produce less heat than standard halogen bulbs, and use about 35 watts to produce the lights
i think that's about it, correct me if i made a mistake, thanks
hid ballast x2
Sarasota's Premier Automotive Community
