Autometer water temp install question...
Old Dec 31, 2004 | 08:03 AM
JDMbyBlood's Avatar
Default Autometer water temp install question...
Hello Gents.
The wife........Oops, I mean Santa brought some autometer gauges. All look simple enough to install, air/fuel, boost, oil pres, volt, but I need a little help with one of the them. The water temp. Is there something I can buy that you cut the upper rad. hose in half and install a adapter that the temp sensor screws in? If not. how does one go about installing the water temp gauge? I guess I could weld one up, but thought I would check with you guys first.
Thanks,
Old Dec 31, 2004 | 09:32 AM
Jap's Avatar
Jap
VTEC Out
I Know they make those adapters for the upper radiator hose in metric threaded gauge senders ..
HKS , Juran alot of companies do , Usually run 10-30 bucks
Hondata saves lives
Old Dec 31, 2004 | 11:34 AM
JDMbyBlood's Avatar
If I were to get a piece of steel EMT, lets say 3-4" long, then weld a nut (Have to use my new welder for something..*LOL*) that the sensor would thread in, then cut the upper rad. hose then install the pipe... would this work? Would I have to coat the inside of the pipe with anything to prevent rust?
Thanks
Old Dec 31, 2004 | 12:54 PM
JDMbyBlood's Avatar
Thanks Fordified. I'll take a trip to HD and see if I can make something work.
Old Jan 1, 2005 | 05:20 PM
TampaTSi's Avatar
some aftermarket aluminum raditators have a water temp bung on them
1998 Eclipse GST
