heat wrap/shielding
Old Dec 20, 2004 | 06:43 PM
dan's Avatar
dan
Get the fuck off my lawn
Default heat wrap/shielding
i want to say i saw some at amazon hose, but i want to know if any other places might be closer and/or cheaper.
i need heat shielding (like the orange firewrap stuff) for an oil return line (passes real close to manifold), and brake, a/c, power steering lines, and heat wrap for brake and power steering reservoirs...
also an inconel turbine housing blanket, but none of that shitty sheetmetal ones those suck.
Old Dec 21, 2004 | 02:11 PM
0HP930's Avatar
Guest
If you need a quick solution for now just buy a roll of the thick aluminum foil, wrinkle it up and wrap it around what you need to protect.
It may look a bit ghetto but it will protect what you need it to until you can find a permanant solution.
