07 Cobra-- nuff said
Old Dec 12, 2004 | 11:53 PM
69 Mach 1's Avatar
Fry Rice
Default 07 Cobra-- nuff said
I checked for reposts...how accurate is this? dont ask me.
Motor: 5.4 Supercharged, 3 valve heads (with HUGE valves), forged internals similar to the 4.6 (Crank, rods, etc), modestly rated (under rated actually) ~465 HP/495 lb ft Torque, using a twin screw S/C similar to that on the Ford GT but pullied differently, hence the lower HP. This motor was supposedly made official (in house only) just in the last few days. It will NOT be rated the equal or even close HP-wise as the Ford GT exotic for exclusivity reasons. It will have more restrictive intake/exhaust systems than the Ford GT which is partly to blame for the lower performance numbers. Also, a cold air induction system will purportedly being looked at as an option but may be standard if it can get past the bean counters.
Transmissions: 6 speed manuals standard with a heavy duty 5 speed auto (the tranny used on the Ford Superduty but programmed/geared differently) as an option in late '07 or the '08 M/Y.
Suspensions: A re-engineered, heavy duty IRS will be an option with a modified 3 link/panhard bar-live axle setup as the standard rear axle. SVT will be going for the Road Race buyer as well as the straight line racer with both axles optional. However, the Axle options are not set in stone as of the moment but look highly likely to be approved. The Cobra will be lowered about 1.5" from a stock GT.
Bodywork: The retro theme will continue with a serious nod to the '67 Shelby. The fenders may be flared more than the standard '05 but that is not for certain as of now. The ducktail will be factory installed. Also, no convertible is planned for now but no reason was given other than concerns over chassis reliability due to the torque volume.
According to "John Doe" (he does not want to get 'relieved' of his assignment), only 3 of the Cobra protos built so far have the S/C'd 5.4 in them. There are actually 6 or 7 on the streets now, not all at the same time but there are similarly painted versions of different cars. There are also supposed to be three Protos with 6+ liter motors in them, 2 with blowers, one that is N/A but these will not be used in the next generation Cobra.
Supposedly, the 6+ Liter motors (he does not know the precise specs on them) are a Hurricane based engine with radical camming and a "first for Ford style of fuel delivery." I have no idea what he means by that and he would not elaborate to my sister either - apparently he was only repeating what he was told.
Tires: Alledgedly, the 5.4 S/C'd cars are running 315's on the rears, 275's on the fronts using 18" rims. Similar setups are on the other Protos. However, the 315's may only be optional with 295's being the standard fare.
Performance: The 5.4 S/C'd cars have been clocked in the very low 12's (12.10-12.25) in the quarter at nearly 120 mph and have been traction limited, according to "John". They are also supposedly able to pull over 1 G in handling.
Per "John", SVT is also adding enormous brakes and will be using an air cooled Intercooler, opting away from the water cooled version used previously due to reliability concerns (?). Other touches will possibly include some form of active/adjustable suspension as an option but he did not know much about it.
Supposedly, we should expect a price to be in the very high $30k range (base price - 6 speed, live axle, base tire/wheel combos) according to his sources in the know.
Also - prototype Mach 1's are also on the streets. These are supposedly running N/A'd 5.4's, tuned for 370hp with the 6 speed transmissions for now and debate still ongoing about which auto to use. None of the proto Mach's are running the Shaker hood to keep them cloaked to spying eyes. This car is supposed to appear for the '06 M/Y with some final tweaking to be set in stone by Jan/Feb 2005.
AIM: AndrewPaulJones
Old Dec 12, 2004 | 11:58 PM
craig_302's Avatar
boostmonkey
If that is true, I blew a load threw my pants, my monitor, the plaster coated cinder block wall reinforced with steel i-beams and scorched the lawn. Please make that, Ford. I won't be able to afford it, just blow loads on it.
Old Dec 13, 2004 | 12:08 AM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Hot. Just plain hotness. Oh, man, I don't care that I won't be able to afford one, I'll buy one anyway, dammit.
Old Dec 13, 2004 | 01:20 AM
craig_302's Avatar
boostmonkey
Kidney for sale/trade for new Cobra/Ford GT and insurance coverage.
Old Dec 13, 2004 | 02:02 AM
69 Mach 1's Avatar
Fry Rice
hmm underpowerd car with 500tq 550 maybe with pulleys and exhaust for 40k.. if thats true i'll expect to see many of these on the road
Old Dec 13, 2004 | 04:20 AM
78mphgpr's Avatar
under estimated
If it is 465 stock, expect to see close to 600 at the wheels for a $1k or 2. Sounds like a pulley, tune, and exhaust will free up some serious power.
Old Dec 13, 2004 | 04:36 AM
TheShow50h's Avatar
The little 5.0 that could
I bet the new mach 1 will look absolutely sick teamed with the new retro body style.
-Vince
Old Dec 13, 2004 | 07:28 AM
BigBadBuick's Avatar
Livin' Large
If this is true, I will be aquiring my first brand spanking new vehicle in over ten years
Old Dec 13, 2004 | 08:00 AM
Rdline1's Avatar
Hi Hi Hi?
sounds awesome.....im not even a big fan of mustangs, but that sounds like a great deal
98 Camry w00t! (daily ride)
91' Eclipse GS-t (she's alive!!)
AOL IM: usfbull49
Originally Posted by Frankie
When a jelly fish comes out of my ass, I'll take pics.
