decisions?
Originally posted by H22madori
by the way , are u doin a SR swap?
500 hp is going to be silly for a daily driven SR. scott managed to squeeze 539 out of a stock block SR but that was by no means his daily driver. personally i'm shooting for about 350 at the wheels. anything above 400 will mean god awful lag as far as i'm concerned. if you're just looking for a dyno number, i'd say go with the sc300
lemme refraise wat i ment , i want a low 12 high 11 sec car that i can drive to work n around town , i'd lik to do the 240 cuz it would be cheaper , 500 was a number i juss through out there
well both cars can be purposely built. you would want to reinforce the SR for 500HP daily driver. thats going to be pretty high maintenance also. any 500hp car is going to be unless its factory.
either car is capable of meeting your needs. Personally I'd do a 240 no if's and's or but's.
Daily driver(reliability, good gas mileage, no problems)and 11 second car do not mix. Pick up a dependable, cheap no frills good gas mileage car and then start a project car. When you have to go to work on Monday morning, you don't have to worry about the rod that's poking out of your oil pan on Sunday night.
And if you're genuinely interested in making a fast car on a tight budget stick with domestics, trust me I own both.
"There's more flawless engineering in a Camry than all the berlinettas Enzo ever conjured while lying next to mistresses." - John Phillips/Car and Driver
The swapped hatch hotness
Slow Five-Oh Rustang
Guest
Posts: n/a
1f y0u h4v3 4 g00d d|21v3|2 4|\|d g00d 7|24c710|\|, 240 c4|\| 533 11'5 \^/17h 350hp 0|\| 4 l1gh7 c4|2, 400 \^/17h 4 full \^/31gh7 c4|2. 5C300 \^/0uld b3 much m0|23 3><p3|\|51v3 70 bu1ld, h34v13|2, bu7 4 |\|1c3|2 c4|2 1MH0. Y0u'd h4v3 70 pu5h 4b0u7 430-450\^/hp 70 h17 115 1|\| 7h47 c4|2, 455um1|\|g y0u h4v3 g00d 7|24c710|\|.
\^/h1ch3v3|2 f175 y0u|2 budg37, d0 7h47 0|\|3.
