1994 Eclipse HELP ASAP
Old Oct 8, 2004 | 08:07 AM
biggnick's Avatar
PS3: BiggNickTR
Default 1994 Eclipse HELP ASAP
I posted in Mitsu Tech as well, but need this running ASAP! Thanks all!
Got a 1994 Eclipse GS 1.8L SOHC 4G37 engine (hey, it was a trade for my '88 Cougar...lol). When you go to start the car, the starter and ignition TRY to turn over, but the car won't kick into that final stage to start. Timing belt, balancer belt, oil, radiator, water pump, starter, and fuses have all been checked. All belts are turning and no electrical problems. And yes, the electronic starter chip is in it!
Just put gas into the car, we thought that might be the problem if the gas gauge is broken. Put in about 2.5 gallons in, thought that should be enough to start it. No leaks anywhere (water, oil, or gas).
Car only has 131k on it, and I need it working asap (deliver pizzas). My 2G Mirage took a shit (auto tranny w/o reverse or neutral, and neutral is now 1st gear?!?
Any help on getting this working would be of massive thanks. Please let me know what to do!
Old Oct 8, 2004 | 08:13 AM
Tits McGee's Avatar
is cooler than you
almost dead battery? toasted spark plug wires?
Old Oct 8, 2004 | 08:24 AM
Ian MMF's Avatar
Omnipotence
Read my post in mitsu tech where this is also posted.
Old Oct 10, 2004 | 10:49 AM
Mr.Focker's Avatar
Guest
you need to get a new job if thats the car you have!
Old Oct 12, 2004 | 03:00 AM
Steez's Avatar
Keep it REAL
You need to get a life if all you can do is be on TR and diss people, stupid ass
[/e-thug]
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Old Oct 12, 2004 | 08:01 AM
Xiwei's Avatar
Kung Fu comes standard™
the transmission on the mirage, could it have been the gear selecter module?
i worked on a car where the shifter line was bolted on the wrong hole on the gear selecter on the transmission, it fixed it after i put it back on the correct spot
Old Oct 12, 2004 | 08:15 AM
Solar Specialist's Avatar
SOLAR-SPECIALIST.COM
Check for spark. Pull a wire off a plug and set it on something metal. Then have someone crank the car and see if theres a spark. If so, move onto fuel. Does the car just keep turning over or what? Flooded possibly? Have you tried push starting it (assuming its a manual)?
Old Oct 12, 2004 | 08:55 AM
biggnick's Avatar
PS3: BiggNickTR
Nah, the plates on the mirage froze up (or so I've been told) and thta is why neutral is 1st gear and there is no reverse or manual.
As far as the Eclipse goes, there IS spark, it is an auto, and the only thing I haven't tried is the fuel pump. It just keep turning over and doesn't "kick" in.
I will most likely be selling the Eclipse so I can have cash to buy a new car at a "Buy here Pay here" place, as I have very little money and not a lot of credit. If I sell the Eclipse and then take that cash and try trading in the Mirage, I think it will be enough for a down payment to finance. Look for it in car sale if you are interested in it.
