switching from conventional to synthenic
Originally posted by Illswyn
Oh and to answer your question, you just get an engine cleaner that you run in the engine. When I switched to Amsoil I bought the engine cleaner also. You change the oil, add it, then regular oil, then run it 20 minutes at high idle, not driving it. Drain the oil, refill with synthetic, change filter, and you're done.
