Dual battery setup?
Old Aug 18, 2004 | 06:02 PM
VetteS10's Avatar
Will Work for Traction!
Default Dual battery setup?
Who runs dual batteries?
whats good?
series, parallel, with isolator without??
I need more power!
I'm running a 140amp alternator... any suggestions on the way I should set it up for duals??
"I am a professional... Ooo what does this button do?..."
AIM: FlyCustomz
Old Aug 18, 2004 | 06:11 PM
Josh's Avatar
Dr. Doom
you need an isolator. if you parrallel them you'll be running 24v :o
Old Aug 19, 2004 | 03:35 AM
cali's Avatar
Skittle on crack!
Wrong answer.
Batteries in parallel produce the same voltage.
Available current however is increased.
You can quit watching me now....
Old Aug 19, 2004 | 03:40 PM
HAVIK's Avatar
Is That Turbo? Psssst!
Originally posted by cali
Wrong answer.
I think your wrong. you need a battery isolater available from stinger or monster. Dually's run off of two batteries
Old Aug 19, 2004 | 04:36 PM
Rich's Avatar
Old School.
Wrong answer.
This is correct. Why do you think you hook up positive to positive and negative to negative on a battery when jump starting a car. You want the same voltage, but the available amperage from the 2nd battery.
Old Aug 19, 2004 | 04:40 PM
HAVIK's Avatar
i see so if its +- and -+ then it would be 24volts like in a remote back to back bateries
Old Aug 19, 2004 | 04:43 PM
cali's Avatar
Skittle on crack!
no
+- and + - would be 24V
Old Aug 19, 2004 | 04:45 PM
HAVIK's Avatar
no
That what i said(or ment)
RussianKid's Avatar
NA > Turbo
i learn something new every day. kudos 4 me, mmmm kuuuudooos im gonna go play som PGR2
Old Aug 19, 2004 | 05:02 PM
rangcrx's Avatar
engine building &best
i have 3 batterys i run them + + + and - - - all grounded to same area
i love AUTOZONE
